Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Introduction
Go to step 1 ↓This guide is used to disassemble the lens from the camera. This will be used to further clean the lens if you experience the E18 error.
Remove the two screws that connect the LCD and backlight to the main body of the camera.
Tool used on this step:Tweezers$4.99
Unplug the ribbon from the housing on the circuitry.
Take the new ribbon and insert it into the housing.
Tweezers or a tool with a sharp point can be used.
Detach the LCD and backlight.
Remove the larger screw.
Remove the two smaller sized screws.
Remove the small screw.
Once you have removed the lens from the main chassis, gently brush off any dirt, sand, or dust that may have accumulated in the crevices. Using a compressed air canister or a brush can help remove all the dirt.
2 other people completed this guide.
