Disassembling Canon PowerShot SD1100 IS LCD screen
    1. Disassembling Canon PowerShot SD1100 IS LCD screen, Front and Rear Cover: step 1, image 1 of 2 Disassembling Canon PowerShot SD1100 IS LCD screen, Front and Rear Cover: step 1, image 2 of 2
      • Remove wrist strap and battery.
      Ask FixBot
    2. Disassembling Canon PowerShot SD1100 IS LCD screen: step 2, image 1 of 3 Disassembling Canon PowerShot SD1100 IS LCD screen: step 2, image 2 of 3 Disassembling Canon PowerShot SD1100 IS LCD screen: step 2, image 3 of 3
      • Remove 2 screws from each side of the camera (4 total, 0.102 in).
      • Remove 2 screws from the bottom on the camera (0.138 in).
      • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
      Ask FixBot
    3. Disassembling Canon PowerShot SD1100 IS LCD screen: step 3, image 1 of 3 Disassembling Canon PowerShot SD1100 IS LCD screen: step 3, image 2 of 3 Disassembling Canon PowerShot SD1100 IS LCD screen: step 3, image 3 of 3
      • Gently pull off the front cover.
      • The plate on the side should come off.
      • Gently pull off the back cover.
      Ask FixBot
    4. Disassembling Canon PowerShot SD1100 IS LCD screen: step 4, image 1 of 1
      • The cases should now be removed.
      Ask FixBot
    1. Disassembling Canon PowerShot SD1100 IS LCD screen, LCD screen: step 5, image 1 of 2 Disassembling Canon PowerShot SD1100 IS LCD screen, LCD screen: step 5, image 2 of 2
      • Remove the top-left screw above the LCD screen (0.100 in).
      • Remove the C-shaped plate from the side of the LCD screen.
      Ask FixBot
    2. Disassembling Canon PowerShot SD1100 IS LCD screen: step 6, image 1 of 2 Disassembling Canon PowerShot SD1100 IS LCD screen: step 6, image 2 of 2
      • Remove the screw from the top-right of the LCD screen (0.098 in).
      • Remove the L-shaped bar from the right of the LCD screen.
      Ask FixBot
    3. Disassembling Canon PowerShot SD1100 IS LCD screen: step 7, image 1 of 2 Disassembling Canon PowerShot SD1100 IS LCD screen: step 7, image 2 of 2
      • Use the spudger to remove the L-shaped bar from the left-side of the LCD screen.
      Ask FixBot
    4. Disassembling Canon PowerShot SD1100 IS LCD screen: step 8, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to remove the connector ribbon from the top-left corner above the LCD screen.
      • Be gentle. This ribbon should stay attached to the screen.
      Ask FixBot
    5. Disassembling Canon PowerShot SD1100 IS LCD screen: step 9, image 1 of 3 Disassembling Canon PowerShot SD1100 IS LCD screen: step 9, image 2 of 3 Disassembling Canon PowerShot SD1100 IS LCD screen: step 9, image 3 of 3
      • Use a spudger to lift the connector lock (black flap) at the end of the larger LCD connector ribbon on the front side of the camera.
      • Use the tweezers to lift this ribbon.
      • Use the tweezers to gently peel this ribbon from the one underneath it.
      Ask FixBot
    6. Disassembling Canon PowerShot SD1100 IS LCD screen: step 10, image 1 of 1
      • The LCD screen should now be removed.
      Ask FixBot
3 other people completed this guide.
Tyler Grossheim
1,623 Reputation
6 Guides authored
Cal Poly, Team 3-32, Regan Winter 2011 Member of Cal Poly, Team 3-32, Regan Winter 2011
CPSU-REGAN-W11S3G32
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 46
All Time: 4,254
