Disassembling Canon PowerShot SD1100 IS Front and Rear Cover
  1. Disassembling Canon PowerShot SD1100 IS Front and Rear Cover, Front and Rear Cover: step 1, image 1 of 2 Disassembling Canon PowerShot SD1100 IS Front and Rear Cover, Front and Rear Cover: step 1, image 2 of 2
    • Remove wrist strap and battery.
    Ask FixBot
  2. Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: step 2, image 1 of 3 Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: step 2, image 2 of 3 Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: step 2, image 3 of 3
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
    Ask FixBot
  3. Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: step 3, image 1 of 3 Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: step 3, image 2 of 3 Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: step 3, image 3 of 3
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
    Ask FixBot
  4. Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: step 4, image 1 of 1
    • The cases should now be removed.
    Ask FixBot
3 other people completed this guide.
Tyler Grossheim
1,623 Reputation
6 Guides authored
Cal Poly, Team 3-32, Regan Winter 2011 Member of Cal Poly, Team 3-32, Regan Winter 2011
CPSU-REGAN-W11S3G32
3 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 68
All Time: 3,838
