Up to 20% off select tools
Disassembling Canon PowerShot S50 Outer Casing
Views: 2.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
104
All Time:
2,615
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to remove the back panel of the camera.
    1. Disassembling Canon PowerShot S50 Outer Casing, Battery: step 1, image 1 of 2 Disassembling Canon PowerShot S50 Outer Casing, Battery: step 1, image 2 of 2
      • Place camera LCD side up and press up on the battery door.
      • Let it swing open until you can see the battery inside.
      Ask FixBot
    2. Disassembling Canon PowerShot S50 Outer Casing: step 2, image 1 of 1
      • Press down on the orange plastic.
      • This will gently eject the battery from its compartment.
      Ask FixBot
    3. Disassembling Canon PowerShot S50 Outer Casing: step 3, image 1 of 2 Disassembling Canon PowerShot S50 Outer Casing: step 3, image 2 of 2
      • Holding the edges, slide out the battery.
      Ask FixBot
    1. Disassembling Canon PowerShot S50 Outer Casing, Front Panel/Battery Door: step 4, image 1 of 1
      • Look at the camera from the side with the lanyard and 4 screws.
      • Remove the two 3.4 mm screws on the metallic colored part.
      Ask FixBot
    2. Disassembling Canon PowerShot S50 Outer Casing: step 5, image 1 of 1
      • Remove the 3mm screw on the top left.
      • NOTE: When reassembling, it is helpful to put the top screw back in before placing the front cover back on the camera.
      • Now remove the 5.3mm screw on the bottom.
      Ask FixBot
    3. Disassembling Canon PowerShot S50 Outer Casing: step 6, image 1 of 1
      • Place the camera LCD side down.
      • Remove the two 5.3mm screws by the battery door.
      Ask FixBot
    4. Disassembling Canon PowerShot S50 Outer Casing: step 7, image 1 of 1
      • Remove the four 3.4mm screws on the bottom of the camera around the tripod mount.
      • Make sure to keep these screws separate from the previous 5.3 mm screws.
      Ask FixBot
    5. Disassembling Canon PowerShot S50 Outer Casing: step 8, image 1 of 1
      • Stand the camera back up.
      • Remove the two 3.6mm screws on the side with the A/V Out port.
      Ask FixBot
    6. Disassembling Canon PowerShot S50 Outer Casing: step 9, image 1 of 1
      • Lift open the rubber flap covering the A/V Out port.
      • Remove the 3.4mm screw in the center.
      • During reassembly, put the A/V out rubber door on before replacing the front panel of the camera
      Ask FixBot
    7. Disassembling Canon PowerShot S50 Outer Casing: step 10, image 1 of 1
      • Use a spudger and gently open up the front panel of the camera.
      • A thin plastic ribbon will stay connected by a brown piece to front panel of the camera.
      Ask FixBot
    8. Disassembling Canon PowerShot S50 Outer Casing: step 11, image 1 of 1
      • There will be a brown plastic piece keeping the thin plastic ribbon in place.
      • Use the spudger to pull out the brown plastic piece attached to the orange plastic.
      Ask FixBot
    9. Disassembling Canon PowerShot S50 Outer Casing: step 12, image 1 of 1
      Tool used on this step:
      Buy
      • Use a pair of tweezers and remove the metal piece inside the camera.
      Ask FixBot
    10. Disassembling Canon PowerShot S50 Outer Casing: step 13, image 1 of 1
      • Remove the battery door
      • NOTE: Putting this back on requires aligning the spring on the back of the door with the hole on the camera
      Ask FixBot
    1. Disassembling Canon PowerShot S50 Outer Casing, Outer Casing: step 14, image 1 of 1
      • Using a spudger, gently separate the back panel from the rest of the camera and remove it.
      Ask FixBot
Author
with
Karim
45 Reputation
3 Guides authored
Cal Poly, Team 7-34, Maness Spring 2012 Member of Cal Poly, Team 7-34, Maness Spring 2012
CPSU-MANESS-S12S7G34
5 Members
72 Guides authored
1 Guide Comment
Hey, i have this camera, and i recently dropped it :( a big part of the buttons don’t work anymore. do you have any idea what i can do to fix it?
Luna Scholten - Reply Share
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 104
All Time: 2,615
