Disassembling Canon Pixma MP480 Rear and Side Panel
    1. Disassembling Canon Pixma MP480 Rear and Side Panel, Rear and Side Panel: step 1, image 1 of 2 Disassembling Canon Pixma MP480 Rear and Side Panel, Rear and Side Panel: step 1, image 2 of 2
      • Remove the two 7.9 mm screws using a Phillips #1 screwdriver.
      Ask FixBot
    2. Disassembling Canon Pixma MP480 Rear and Side Panel: step 2, image 1 of 1
      • Lift up the back cover to remove it.
      • You may need to lift firmly as it requires quite a bit of force.
      Ask FixBot
    3. Disassembling Canon Pixma MP480 Rear and Side Panel: step 3, image 1 of 1
      • Open the front tray.
      Ask FixBot
    4. Disassembling Canon Pixma MP480 Rear and Side Panel: step 4, image 1 of 2 Disassembling Canon Pixma MP480 Rear and Side Panel: step 4, image 2 of 2
      • Open the scanner compartment.
      • Make sure the blue lever locks into place to keep the compartment open.
      Ask FixBot
    5. Disassembling Canon Pixma MP480 Rear and Side Panel: step 5, image 1 of 2 Disassembling Canon Pixma MP480 Rear and Side Panel: step 5, image 2 of 2
      • Remove the blue lever from its slot by pushing it back and twisting clockwise.
      • Close the scanner compartment and cover.
      Ask FixBot
    6. Disassembling Canon Pixma MP480 Rear and Side Panel: step 6, image 1 of 2 Disassembling Canon Pixma MP480 Rear and Side Panel: step 6, image 2 of 2
      • Pry open the side cover with the plastic opening tool.
      Ask FixBot
    7. Disassembling Canon Pixma MP480 Rear and Side Panel: step 7, image 1 of 2 Disassembling Canon Pixma MP480 Rear and Side Panel: step 7, image 2 of 2
      • Flip the printer over so that the bottom of the printer is facing you.
      • Use the plastic opening tool to remove the corner of the side panel from the plastic pin.
      Ask FixBot
    8. Disassembling Canon Pixma MP480 Rear and Side Panel: step 8, image 1 of 2 Disassembling Canon Pixma MP480 Rear and Side Panel: step 8, image 2 of 2
      • Use the plastic opening tool to loosen the side panel from the bottom of the printer.
      Ask FixBot
6 other people completed this guide.
Kevin Cole
116 Reputation
1 Guide authored
Cal Poly, Team 19-41, Regan Winter 2013 Member of Cal Poly, Team 19-41, Regan Winter 2013
CPSU-REGAN-W13S19G41
4 Members
72 Guides authored
2 Guide Comments
Good job!!!!
lhitvietnam - Reply Share
Where is the rest of disassembly?
bill roberts - Reply Share
Past 24 Hours: 2
Past 7 Days: 32
Past 30 Days: 116
All Time: 22,038
