Disassembling Canon EOS Rebel XS Top Panel
    1. Disassembling Canon EOS Rebel XS Top Panel, Latch Side Cover: step 1, image 1 of 1
      • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
      Ask FixBot
    2. Disassembling Canon EOS Rebel XS Top Panel: step 2, image 1 of 1
      • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
      • Pry up the panel; starting from the front/bottom corner, as indicated.
      • There's a concealed lip, under the opposite edge.
      Ask FixBot
    1. Disassembling Canon EOS Rebel XS Top Panel, Disassembling Canon EOS Rebel XS Front Cover: step 3, image 1 of 1
      • Remove three medium length screws from the bottom of the camera
      Ask FixBot
    2. Disassembling Canon EOS Rebel XS Top Panel: step 4, image 1 of 1
      • Remove the two medium length screws on the front panel of the camera above the lens mount.
      • Once you done, you may use the Spudger to panel from non-grip side.
      • If you start on the grip side, it will be more challenging to loosen the panel.
      Ask FixBot
    1. Disassembling Canon EOS Rebel XS Top Panel, Back Cover: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Remove the three long black screws from the bottom using a #00 Phillips screwdriver.
      • Use tweezers to lift the panel.
      Ask FixBot
    2. Disassembling Canon EOS Rebel XS Top Panel: step 6, image 1 of 1
      • Once you have detached the back cover, use a pair of tweezers to lightly pull on strap found connecting the back cover to the camera.
      Ask FixBot
    1. Disassembling Canon EOS Rebel XS Top Panel, Top Panel: step 7, image 1 of 1
      Buy
      • Remove the following ribbons with the tweezers by gently pulling on them.
      • Remove the three black screws, near the eye piece, using the Phillips Screwdriver.
      Ask FixBot
    2. Disassembling Canon EOS Rebel XS Top Panel: step 8, image 1 of 1
      • Remove the cable heads attached on the front side of the camera next to the lens mount.
      • Be gentle when puling wires lose, use the tweezers to remove the wires.
      Ask FixBot
    3. Disassembling Canon EOS Rebel XS Top Panel: step 9, image 1 of 1
      • You can use your fingers to pull the top panel of the camera.
      Ask FixBot
Daniel Bussone
1,289 Reputation
11 Guides authored
Cal Poly, Team 3-41, Regan Winter 2011 Member of Cal Poly, Team 3-41, Regan Winter 2011
CPSU-REGAN-W11S3G41
2 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 32
All Time: 4,694
