Disassembling Canon EOS Rebel XS Front Cover
    1. Disassembling Canon EOS Rebel XS Front Cover, Latch Side Cover: step 1, image 1 of 1
      • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
      Ask FixBot
    2. Disassembling Canon EOS Rebel XS Front Cover: step 2, image 1 of 1
      • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
      • Pry up the panel; starting from the front/bottom corner, as indicated.
      • There's a concealed lip, under the opposite edge.
      Ask FixBot
    1. Disassembling Canon EOS Rebel XS Front Cover, Disassembling Canon EOS Rebel XS Front Cover: step 3, image 1 of 1
      • Remove three medium length screws from the bottom of the camera
      Ask FixBot
    2. Disassembling Canon EOS Rebel XS Front Cover: step 4, image 1 of 1
      • Remove the two medium length screws on the front panel of the camera above the lens mount.
      • Once you done, you may use the Spudger to panel from non-grip side.
      • If you start on the grip side, it will be more challenging to loosen the panel.
      Ask FixBot
2 other people completed this guide.
Daniel Bussone
1,289 Reputation
11 Guides authored
Cal Poly, Team 3-41, Regan Winter 2011 Member of Cal Poly, Team 3-41, Regan Winter 2011
CPSU-REGAN-W11S3G41
2 Members
132 Guides authored
3 Guide Comments
This should be labelled: Easy.
tjt263 - Reply Share
Okay, there are several steps missing.
This is impossible to follow, there must be several things missing here
Fredrik Sjöborg - Reply Share
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 31
All Time: 5,910
