Disassembling Canon EOS Rebel XS Battery Door
  1. Disassembling Canon EOS Rebel XS Battery Door, Latch Side Cover: step 1, image 1 of 1
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
    Ask FixBot
  2. Disassembling Canon EOS Rebel XS Battery Door: step 2, image 1 of 1
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
    Ask FixBot
  3. Disassembling Canon EOS Rebel XS Battery Door, Disassembling Canon EOS Rebel XS Front Cover: step 3, image 1 of 1
    • Remove three medium length screws from the bottom of the camera
    Ask FixBot
  4. Disassembling Canon EOS Rebel XS Battery Door: step 4, image 1 of 1
    • Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Once you done, you may use the Spudger to panel from non-grip side.
    • If you start on the grip side, it will be more challenging to loosen the panel.
    Ask FixBot
  5. Disassembling Canon EOS Rebel XS Battery Door, Grip: step 5, image 1 of 1
    • Remove the two 4.5mm (.18in) long black screws from the camera grip using a #00 Phillips screwdriver.
    Ask FixBot
  6. Disassembling Canon EOS Rebel XS Battery Door: step 6, image 1 of 1
    • Use your fingertip to pry off the external shutter port cover.
    Ask FixBot
  7. Disassembling Canon EOS Rebel XS Battery Door: step 7, image 1 of 1
    • Remove the two 5mm (.20in) long silver screws securing the grip to the camera using a #00 Phillips screwdriver.
    Ask FixBot
  8. Disassembling Canon EOS Rebel XS Battery Door: step 8, image 1 of 3 Disassembling Canon EOS Rebel XS Battery Door: step 8, image 2 of 3 Disassembling Canon EOS Rebel XS Battery Door: step 8, image 3 of 3
    • Use the spudger tool to carefully pry the grip from the rest of the camera.
    Ask FixBot
  9. Disassembling Canon EOS Rebel XS Battery Door: step 9, image 1 of 1
    • Once the grip is loose, use your fingers to remove it from the camera.
    Ask FixBot
  10. Disassembling Canon EOS Rebel XS Battery Door, Battery Door: step 10, image 1 of 1
    • Remove the 4.8mm (.19in) long silver screw from the inside of the grip.
    Ask FixBot
  11. Disassembling Canon EOS Rebel XS Battery Door: step 11, image 1 of 2 Disassembling Canon EOS Rebel XS Battery Door: step 11, image 2 of 2
    • Remove the hinge of the battery door from the inside of the grip.
    • Our sample camera's battery door was broken off of its hinge. Picture two shows an example of a battery door that is not broken.
    Ask FixBot
Daniel Bussone
1,289 Reputation
11 Guides authored
Cal Poly, Team 3-41, Regan Winter 2011 Member of Cal Poly, Team 3-41, Regan Winter 2011
CPSU-REGAN-W11S3G41
2 Members
21 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 43
All Time: 5,482
