Disassembling Canon EOS Rebel XS Back Cover
    1. Disassembling Canon EOS Rebel XS Back Cover, Latch Side Cover: step 1, image 1 of 1
      • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
      Ask FixBot
    2. Disassembling Canon EOS Rebel XS Back Cover: step 2, image 1 of 1
      • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
      • Pry up the panel; starting from the front/bottom corner, as indicated.
      • There's a concealed lip, under the opposite edge.
      Ask FixBot
    1. Disassembling Canon EOS Rebel XS Back Cover, Back Cover: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Remove the three long black screws from the bottom using a #00 Phillips screwdriver.
      • Use tweezers to lift the panel.
      Ask FixBot
    2. Disassembling Canon EOS Rebel XS Back Cover: step 4, image 1 of 1
      • Once you have detached the back cover, use a pair of tweezers to lightly pull on strap found connecting the back cover to the camera.
      Ask FixBot
2 other people completed this guide.
Daniel Bussone
1,289 Reputation
11 Guides authored
Cal Poly, Team 3-41, Regan Winter 2011 Member of Cal Poly, Team 3-41, Regan Winter 2011
CPSU-REGAN-W11S3G41
2 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 44
All Time: 4,488
