Disassembling Cambridge Audio A3i Case
Views: 4.9K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
91
All Time:
4,895
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide describes the steps to opening the case.
    1. Disassembling Cambridge Audio A3i Case, Case: step 1, image 1 of 1
      • Remove 2 screws from each side of the amplifier.
      Ask FixBot
    2. Disassembling Cambridge Audio A3i Case: step 2, image 1 of 1
      • Remove 2 screws on rear of device. Slide top cover up and back from main case.
      Ask FixBot
    3. Disassembling Cambridge Audio A3i Case: step 3, image 1 of 2 Disassembling Cambridge Audio A3i Case: step 3, image 2 of 2
      • Remove 3 screws on bottom of case.
      • Remove 13 screws on rear panel.
      • Do not move the rear panel too far, as the power cord is still connected.
      Ask FixBot
    4. Disassembling Cambridge Audio A3i Case: step 4, image 1 of 1
      • Using a pair of pliers, squeeze the retainer for the power cord as shown and pull it toward the external side the panel.
      • It may require some wiggling, but it should slip out of the hole and then off of the cord.
      Ask FixBot
3 other people completed this guide.
Colby
356 Reputation
3 Guides authored
Cal Poly, Team 28-36, Regan Spring 2010 Member of Cal Poly, Team 28-36, Regan Spring 2010
CPSU-REGAN-S10S28G36
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 91
All Time: 4,895
