Disassembling BlackBerry 8820 Outer Casing
    1. Disassembling BlackBerry 8820 Outer Casing, Outer Casing: step 1, image 1 of 1
      • Remove the battery cover by applying pressure and sliding the silver square on the back of the phone downwards.
      Ask FixBot
    2. Disassembling BlackBerry 8820 Outer Casing: step 2, image 1 of 2 Disassembling BlackBerry 8820 Outer Casing: step 2, image 2 of 2
      • Remove the battery by prying under it with your finger or a plastic opening tool.
      • Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
      Ask FixBot
    3. Disassembling BlackBerry 8820 Outer Casing: step 3, image 1 of 2 Disassembling BlackBerry 8820 Outer Casing: step 3, image 2 of 2
      • Carefully remove the two plastic side bars using a nylon spudger.
      Ask FixBot
    4. Disassembling BlackBerry 8820 Outer Casing: step 4, image 1 of 1
      • Carefully pry the back casing off with a nylon spudger.
      • There are two small clamps on each edge that need to be unhooked before the casing can come off.
      Ask FixBot
    5. Disassembling BlackBerry 8820 Outer Casing: step 5, image 1 of 1
      • Pry off the front casing.
      • Be cautious of sensors and other sensitive areas of the newly exposed electronics.
      Ask FixBot
ryan
44 Reputation
5 Guides authored
Cal Poly, Team 13-64, Johann Spring 2013 Member of Cal Poly, Team 13-64, Johann Spring 2013
CPSU-JOHANN-S13S13G64
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 21
All Time: 1,274
