Disassembling BT Baby Monitor 250 Power switch
Views: 2.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
93
All Time:
2,142
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓
How to dismantle, resolder power switch, and reassemble the BT 250 Baby Monitor
Tools
    1. Disassembling BT Baby Monitor 250 Power switch, Remove battery cover and batteries: step 1, image 1 of 1
      • Unclip the battery cover, and remove the batteries (they're a tight fit - the purple ribbon should help though)
      Ask FixBot
      • Remove the two phillips screws at the lower edge of the battery compartment
      Ask FixBot
    2. Disassembling BT Baby Monitor 250 Power switch, Separate the casing: step 3, image 1 of 1
      • The casing is now held together by a pair of snap-fixings on each side, which will require careful prising apart.
      • Using the picture as a guide to show where the catches are (red circles), use a small screwdriver or a spudger-type tool to release them levering outwards, then carefully separate the two halves of the casing
      Ask FixBot
    3. Disassembling BT Baby Monitor 250 Power switch, Release the LCD: step 4, image 1 of 1
      • The LCD is held on by a pair of small plastic lugs, one each side. Release these one at a time, while gently lifting the LCD up from the board.
      • Once both clips are released, it will hinge forward and down.
      Ask FixBot
    4. Disassembling BT Baby Monitor 250 Power switch, Release PCB from case: step 5, image 1 of 1
      • Remove the two screws from under the LCD
      • Remove the single screw in the middle of the lower part of the PCB
      • Gently bend up the two charging connectors on the lower edge of the PCB that stick through the case to free it
      • Lift the PCB from the case, lower edge first
      Ask FixBot
    5. Disassembling BT Baby Monitor 250 Power switch, Inspect and repair loose switches: step 6, image 1 of 1
      • With the PCB removed, inspect the switches along the top edge.
      • On mine, the solder holding the switch mounting tabs to the PCB had failed, leaving both tabs and pads intact
      • Carefully resolder these, ensuring enough heat is applied to ensure a good joint, but without damaging neighbouring components
      Ask FixBot
      • Reassembly is the reverse of dismantling.
      • Remember to bend the charging connectors back into place so they are correctly seated
      • Replace the vibrate motor into its' groove.
      • Ensure the switches all operate correctly before clipping the two case halves back together - sometimes the little pieces of adhesive foam on the 'button pressers' need to be adjusted.
      Ask FixBot
davidmpye
101 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 93
All Time: 2,142
