Disassembling Atlantic Vertigo water heater
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
125
All Time:
428
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
To decalc the water heater I disassembled the water heater (or at least what was necessary for the decalc process. The linked video is a similar water heater, although another model. Sorry I didn't take enough pictures on the go, but I believe it still may help someone who wants to do it on their own
Video Overview
      • Unplug the water heater
      • Close the incoming water valve (cold water)
      • Drain the water from the water heater through the emergency exit of the heater.
      • It might be necessary to drain through one or both of the water in- and output valves. Most of the water will come out of the cold water in valve though
      Ask FixBot
      • Open the four screws on bottom plastic cover
      Ask FixBot
    1. Disassembling Atlantic Vertigo water heater, Electric dissasembly: step 3, image 1 of 1
      • Remove the red and green wires with the 8mm wrench
      • Do this on both sides
      • Remove the ground wire and ground metal connector with the T20 Torx screwdriver
      • 1 screw from the outer wire
      • 2 screws at the end of the connecting rod
      Ask FixBot
      • Gently pull out the thermostat wire and the metal
      • Gently remove the small white insulation around the connecting pipe
      Ask FixBot
      • Hold the brown ceramic squared part and unscrew the single screw at the end of the small curvy metal that holds it in place (Torx T20 screw)
      • Once the screw is removed hold the metal in the hand and gently pull out the long ceramic heating unit
      • Do this on the other side as well
      Ask FixBot
    2. Disassembling Atlantic Vertigo water heater, Remove the complete metal inner part: step 6, image 1 of 1
      • Prepare something to stop the water from making everything wet
      • Loosen the 6 screws holding the big metal cylinder in place.
      • When the last one is loosened, water will come out. Not significant amount, but enough to spill allover
      • You should loosen the screws furthest from each other and not just go around
      • Once the water stops, loosen all screws while holding the metal
      • It's heavy!
      • Gently pull out the metal
      • This will most probably be full with calc, clean it by hand, or with some calc solvent material
      Ask FixBot
      • Remove the rubber sealing around the rim
      • Clean the inner part of the heater gently with a cloth, or just by hand
      • Do not use strong materials, to save the coating of the heater
      Ask FixBot
Bango Bejla
1,511 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 125
All Time: 428
