Up to 20% off select tools
Disassembling Asus W2W-A1 Front Panel
View statistics:
Past 24 Hours:
5
Past 7 Days:
16
Past 30 Days:
77
All Time:
925
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
  • Spudger
    4.9
  • Phillips #0 Screwdriver
    5
    1. Disassembling Asus W2W-A1 Front Panel, Keyboard: step 1, image 1 of 3 Disassembling Asus W2W-A1 Front Panel, Keyboard: step 1, image 2 of 3 Disassembling Asus W2W-A1 Front Panel, Keyboard: step 1, image 3 of 3
      • Remove the battery, then unscrew the 7 3 mm Phillips screws behind the battery. Make sure they go in separate, organized piles.
      • Unscrew the 2 4 mm Phillips head screws by the battery.
      Ask FixBot
    2. Disassembling Asus W2W-A1 Front Panel: step 2, image 1 of 1
      • Remove the panel above the keyboard with a plastic spudger.
      Ask FixBot
    3. Disassembling Asus W2W-A1 Front Panel: step 3, image 1 of 1
      • Once the panel is removed, use the spudger to pry out the keyboard.
      • Do not fully remove, for the keyboard is still attached to the ribbon cable.
      Ask FixBot
    4. Disassembling Asus W2W-A1 Front Panel: step 4, image 1 of 2 Disassembling Asus W2W-A1 Front Panel: step 4, image 2 of 2
      • Detach the ribbon cable from the keyboard by pulling the end of the ribbon cable that is attached inside of the laptop.
      • Be sure to detach from the root rather than from near the middle. It should slide out with ease.
      • Now you can fully remove the keyboard from the laptop.
      Ask FixBot
    1. Disassembling Asus W2W-A1 Front Panel, Front Panel: step 5, image 1 of 1
      • Place your fingers or a spudger between the front panel and the rest of the laptop.
      • Pull upwards gently to detach the side you are grabbing.
      • Repeat on the other side until the panel easily peels off the laptop.
      Ask FixBot
Author
with
Nolan Schock
501 Reputation
5 Guides authored
Cal Poly, Team 13-29, Maness Spring 2014 Member of Cal Poly, Team 13-29, Maness Spring 2014
CPSU-MANESS-S14S13G29
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 16
Past 30 Days: 77
All Time: 925
