Disassembling Asus FX505G - Inspect Fans - Replace CPU Fan
    1. Disassembling Asus FX505G - Inspect Fans - Replace CPU Fan, Turn over laptop and remove screws: step 1, image 1 of 2 Disassembling Asus FX505G - Inspect Fans - Replace CPU Fan, Turn over laptop and remove screws: step 1, image 2 of 2
      • Size 1 Phillips Screwdriver
      • M2.5x12mm (long) x 6 ORANGE
      • M2.5x6mm (short) x 5 RED
      Ask FixBot
    2. Disassembling Asus FX505G - Inspect Fans - Replace CPU Fan, Remove bottom cover of the laptop: step 2, image 1 of 2 Disassembling Asus FX505G - Inspect Fans - Replace CPU Fan, Remove bottom cover of the laptop: step 2, image 2 of 2
      • Insert an opener into the lower right corner
      • Gently slide the opener around the perimeter of the case opening to release the plastic tabs holding the bottom cover to the case
      Ask FixBot
    3. Disassembling Asus FX505G - Inspect Fans - Replace CPU Fan, Determine which fan is malfunctioning: step 3, image 1 of 1
      • Power on the laptop to get the fans spinning, determine which one is making noise or otherwise not functioning
      • In my case, it was the CPU fan, which corresponded to the alarms I was getting (CPU overheating)
      • CPU fan is on the "right" side if you have the case open with the bottom of the laptop closest to you
      • Thus, the GPU is on the "left" side
      • The fans have slight differences in their footprint
      Ask FixBot
    4. Disassembling Asus FX505G - Inspect Fans - Replace CPU Fan, Disconnect electrical connections, remove fan screws: step 4, image 1 of 1
      • There's a ZIF connecter to disconnect to make it easier to remove the fan
      • Also disconnect the fan's small molex connector
      Ask FixBot
    5. Disassembling Asus FX505G - Inspect Fans - Replace CPU Fan, Remove Fan Screws: step 5, image 1 of 1
      • Remove these two screws
      Ask FixBot
    6. Disassembling Asus FX505G - Inspect Fans - Replace CPU Fan, Remove Fan: step 6, image 1 of 1
      • Gently pull up on adhesive to detach pad from fan plastic arm
      • Gently lift up heat sink to slide fan arm underneath it
      • Remove fan
      Ask FixBot
      • Reverse the instructions to re-install
      • If you have it, you can apply thread lock or Loc-Tite to the screws prior to re-installing.
      Ask FixBot
Eric Franke
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 54
All Time: 264
