Disassembling Arnova 7K G3 Motherboard
    1. Disassembling Arnova 7K G3 Motherboard, Rear Cover: step 1, image 1 of 3 Disassembling Arnova 7K G3 Motherboard, Rear Cover: step 1, image 2 of 3 Disassembling Arnova 7K G3 Motherboard, Rear Cover: step 1, image 3 of 3
      • Remove four 5 mm Phillips #00 screws from each corner of the tablet.
      Ask FixBot
    2. Disassembling Arnova 7K G3 Motherboard: step 2, image 1 of 2 Disassembling Arnova 7K G3 Motherboard: step 2, image 2 of 2
      • Place the iFixit opening tool in the notches between the cases and pull the covers apart.
      Ask FixBot
    3. Disassembling Arnova 7K G3 Motherboard: step 3, image 1 of 1
      • Repeat step two until 3/4 of the rear cover is unlatched.
      • Proceed to remove the rear cover by gently pulling it apart by hand.
      Ask FixBot
    1. Disassembling Arnova 7K G3 Motherboard, Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: step 4, image 1 of 2 Disassembling Arnova 7K G3 Motherboard, Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Peel the copper tape covering the ribbon connector with a set of tweezers.
      Ask FixBot
    2. Disassembling Arnova 7K G3 Motherboard: step 5, image 1 of 3 Disassembling Arnova 7K G3 Motherboard: step 5, image 2 of 3 Disassembling Arnova 7K G3 Motherboard: step 5, image 3 of 3
      • Locate the two gray pins on the ribbon connector.
      • Grab the first pin with tweezers and gently pull it towards the ribbon. Repeat the step.
      • Gently pull the ribbon cable out of the connection port.
      Ask FixBot
    3. Disassembling Arnova 7K G3 Motherboard: step 6, image 1 of 3 Disassembling Arnova 7K G3 Motherboard: step 6, image 2 of 3 Disassembling Arnova 7K G3 Motherboard: step 6, image 3 of 3
      • Locate the ribbon connector two.
      • Locate the pins of ribbon connector two. Repeat step two for unlocking the pins.
      • Gently pull the ribbon out of the connection port.
      Ask FixBot
    1. Disassembling Arnova 7K G3 Motherboard, Disassembling Arnova 7K G3 Motherboard: step 7, image 1 of 1
      • Remove the two Phillips #00 screws from the motherboard.
      Ask FixBot
    2. Disassembling Arnova 7K G3 Motherboard: step 8, image 1 of 1
      • Gently lift up the motherboard and reorient it in a more efficient manner in order to locate the desired components.
      Ask FixBot
Kue
301 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 21
All Time: 682
