Disassembling Apple AirPort Extreme Model A1034 Outer Case
    1. Disassembling Apple AirPort Extreme Model A1034 Outer Case, Outer Case: step 1, image 1 of 1
      • Remove the three 14.3mm T7 Torx screws from the bottom of AirPort.
      Ask FixBot
    2. Disassembling Apple AirPort Extreme Model A1034 Outer Case: step 2, image 1 of 1
      • Remove the 5.1mm Phillips screw from the bottom of the AirPort. This screw is located under the identification sticker. You will have to remove the sticker or make a hole to remove it.
      Ask FixBot
    3. Disassembling Apple AirPort Extreme Model A1034 Outer Case: step 3, image 1 of 2 Disassembling Apple AirPort Extreme Model A1034 Outer Case: step 3, image 2 of 2
      • Lift the bottom and top casing straight apart and then lift metal casing straight up from the bottom plastic casing.
      Ask FixBot
    4. Disassembling Apple AirPort Extreme Model A1034 Outer Case: step 4, image 1 of 1
      • Unplug the black connector on the top of the metal casing by gently pulling horizontally.
      Ask FixBot
2 other people completed this guide.
Travis Go
167 Reputation
2 Guides authored
Cal Poly, Team 17-15, Regan Fall 2011 Member of Cal Poly, Team 17-15, Regan Fall 2011
CPSU-REGAN-F11S17G15
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 111
All Time: 3,549
