Up to 20% off select tools
Disassembling Ambient Weather AQIN Particulate Sensor
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
59
All Time:
388
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 - 10 minutes
Difficulty: Moderate
Community-Contributed Guide
    1. Disassembling Ambient Weather AQIN Particulate Sensor, Particulate Sensor: step 1, image 1 of 3 Disassembling Ambient Weather AQIN Particulate Sensor, Particulate Sensor: step 1, image 2 of 3 Disassembling Ambient Weather AQIN Particulate Sensor, Particulate Sensor: step 1, image 3 of 3
      • Looking at the sensor from the bottom, you can see the two tabs/prongs that hold the outer case together.
      • There is a fine cable attaching the internal components of the PM sensor. Be careful not to disrupt/break it.
      • The internal housing will now be exposed. You can use the two tabs/prongs on this porting to remove that portion of the case.
      • Next, you can remove the 4 small screws holding the internal components to the outer shell.
      Ask FixBot
    2. Disassembling Ambient Weather AQIN Particulate Sensor: step 2, image 1 of 2 Disassembling Ambient Weather AQIN Particulate Sensor: step 2, image 2 of 2
      • Once the unit is disassembled, you can locate the internal motor of the unit.
      • Using compressed air, you may remove any debris that has become lodged on the intake shield of the motor.
      Ask FixBot
Author
with
Tim Elafros
493 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 59
All Time: 388
