Disassembling Acer Iconia A1-830 Back Panel
Views: 6.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
92
All Time:
6,947
Comments: 2
2 guide comments.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Removing the back panel of your Acer Iconia A1-830 tablet gives you access to its inner components. Double check the position of your plastic opening tool before applying force, to make sure it doesn't slip out.
Tools
    1. Disassembling Acer Iconia A1-830 Back Panel, Disassembling Acer Iconia A1-830 Back Panel: step 1, image 1 of 2 Disassembling Acer Iconia A1-830 Back Panel, Disassembling Acer Iconia A1-830 Back Panel: step 1, image 2 of 2
      • Prepare your working space. The ideal work space has a flat, level surface that is clean and well lit.
      • Shut down your Acer Iconia A1-830.
      • Remove any cables or exterior covers from your tablet.
      • Place it on your work space, with the screen facing up.
      Ask FixBot
    2. Disassembling Acer Iconia A1-830 Back Panel: step 2, image 1 of 2 Disassembling Acer Iconia A1-830 Back Panel: step 2, image 2 of 2
      • Wedge the plastic opening tool into the tiny gap between the white plastic front bezel and the aluminum rear panel.
      • Do not try to pry apart the top edge on the front side near the front-facing camera.
      Ask FixBot
10 other people completed this guide.
Matt Champagne
458 Reputation
2 Guides authored
UMass Dartmouth, Team 4-6, Catania Fall 2015 Member of UMass Dartmouth, Team 4-6, Catania Fall 2015
UMASSD-CATANIA-F15S4G6
3 Members
60 Guides authored
2 Guide Comments
Hi iv got an acer icon is one 10.iv done a factory reset ,but it hasent come back ,and it turns on but I can't stop it talking ,volume won't turn down and ,when I checked the volume button it says it turn off .the tablet won't do anything .can you tell me if it's worth repairing and how much if possible. Thank you Teresa spry
Teresa Spry - Reply Share
Can the back of the tablet be completely removed, so i can look at the micro USB port, to see if that is what is not letting the tablet charge !! Without not knowing what I’m doing and messing it up!!
andre_chatel - Reply Share
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 92
All Time: 6,947
