Up to 20% off select tools
Disassembling ASUS K501U
Views: 2.7K
View statistics:
Past 24 Hours:
6
Past 7 Days:
52
Past 30 Days:
247
All Time:
2,699
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes
Difficulty: Moderate
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
Ported from insidemylaptop.com.
Note: older variants of the K501U model ship with a different board layout, only one fan, and without an M.2 drive installed.
    1. Disassembling ASUS K501U, ASUS K501U: step 1, image 1 of 1
      • Place as shown in the photo with the screen hinge at the top. Remove all ten screws from the bottom cover. These screws have different length - longest at the top and shortest at the bottom. I color-coded screws with similar length in red, yellow and green. Make sure to install them correctly when you assemble the laptop back together.
      • Remove the four 10.7mm-long screws along the top edge.
      • Remove the two 6.7mm-long screws along the sides.
      • Remove the four 4.7mm-long screws along the bottom edge.
      Ask FixBot
    2. Disassembling ASUS K501U: step 2, image 1 of 1
      • The bottom cover is held in place by plastic tabs along the outside edges. Using a plastic pry tool, carefully separate the bottom cover from the palmrest assembly and remove it.
      Ask FixBot
    3. Disassembling ASUS K501U: step 3, image 1 of 1
      • The battery is connected to the motherboard via a cable.
      • Remove the four 4.7mm-long screws securing the battery.
      Ask FixBot
    4. Disassembling ASUS K501U: step 4, image 1 of 1
      • In order to unlock the battery connector you’ll have to slide the metal bracket to the shown direction.
      Ask FixBot
    5. Disassembling ASUS K501U: step 5, image 1 of 1
      • Carefully lift up the battery cable from the connector.
      • Do not use metal objects to lift up the cable. You can short metal pins inside. It is recommended that you use a plastic spudger.
      Ask FixBot
    6. Disassembling ASUS K501U: step 6, image 1 of 1
      • You can find a new replacement battery using the part number printed on the original battery. I would recommend using a genuine Asus battery, not a third-party replacement. Replacement battery model B31N1429.
      Ask FixBot
    7. Disassembling ASUS K501U: step 7, image 1 of 1
      • Asus K501U motherboard has only one memory slot. Some memory is built into the motherboard. You can access the available slot if you remove the metal cover. You can install up to 8GB DDR3-12800 SODIMM RAM module into this slot.
      Ask FixBot
    8. Disassembling ASUS K501U: step 8, image 1 of 1
      • Remove four 4.7mm-long screws from the hard drive caddy and remove the caddy. This laptop came with a m.2 solid state drive so there is no regular 2.5″ hard drive installed.
      Ask FixBot
    9. Disassembling ASUS K501U: step 9, image 1 of 1
      • Remove one screw securing the solid state drive and pull the drive out. This is m.2 SATA III solid state drive (not NVMe).
      Ask FixBot
    10. Disassembling ASUS K501U: step 10, image 1 of 1
      • Remove three screws securing the right fan.
      • Disconnect fan cable from the motherboard.
      Ask FixBot
    11. Disassembling ASUS K501U: step 11, image 1 of 1
      • Remove the right fan.
      Ask FixBot
    12. Disassembling ASUS K501U: step 12, image 1 of 1
      • Remove three screws securing the left fan.
      Ask FixBot
    13. Disassembling ASUS K501U: step 13, image 1 of 1
      • Remove the left fan.
      Ask FixBot
    14. Disassembling ASUS K501U: step 14, image 1 of 1
      • The USB audio board is mounted under the right hinge.
      • Remove three screws from the right hinge. Remove one screw from the board.
      • Disconnect the USB audio board cable (color-coded in green).
      • Disconnect the right speaker cable (color-coded in yellow).
      Ask FixBot
    15. Disassembling ASUS K501U: step 15, image 1 of 1
      • Unlock the connector first by lifting up the locking tab.
      • After that pull the cable out.
      Ask FixBot
    16. Disassembling ASUS K501U: step 16, image 1 of 1
      • Lift up the right hinge and remove the USB audio board.
      Ask FixBot
    17. Disassembling ASUS K501U: step 17, image 1 of 1
      • Carefully disconnect wireless antenna cables from the wireless card.
      Ask FixBot
    18. Disassembling ASUS K501U: step 18, image 1 of 1
      • Remove one 4.7mm-long screw securing the wireless card.
      • Pull out the wireless card in the direction shown.
      Ask FixBot
    19. Ask FixBot
Author
with
tqd
3,358 Reputation
17 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 52
Past 30 Days: 247
All Time: 2,699
