Up to 20% off select tools
Disassembling 8BitDo Ultimate Wireless Case
View statistics:
Past 24 Hours:
6
Past 7 Days:
47
Past 30 Days:
243
All Time:
987
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 7 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to open your 8BitDo Ultimate Wireless case.
    1. Disassembling 8BitDo Ultimate Wireless Case, Case: step 1, image 1 of 2 Disassembling 8BitDo Ultimate Wireless Case, Case: step 1, image 2 of 2
      • Insert an opening pick into the seam between the left controller grip and main controller body.
      • Pry the grip off.
      • Repeat for the right grip.
      Ask FixBot
    2. Disassembling 8BitDo Ultimate Wireless Case: step 2, image 1 of 2 Disassembling 8BitDo Ultimate Wireless Case: step 2, image 2 of 2
      • Remove the six 8 mm T6 Torx screws securing the rear case to the front case.
      Ask FixBot
    3. Disassembling 8BitDo Ultimate Wireless Case: step 3, image 1 of 3 Disassembling 8BitDo Ultimate Wireless Case: step 3, image 2 of 3 Disassembling 8BitDo Ultimate Wireless Case: step 3, image 3 of 3
      • Insert an opening tool into seam at the bottom of the device and carefully pry the front and back shells apart.
      • Set the halves next to each other with care not to strain the connected ribbon cables.
      Ask FixBot
    4. Disassembling 8BitDo Ultimate Wireless Case: step 4, image 1 of 3 Disassembling 8BitDo Ultimate Wireless Case: step 4, image 2 of 3 Disassembling 8BitDo Ultimate Wireless Case: step 4, image 3 of 3
      • The ribbon cable is secured with a locking tab connector.
      • Use tweezers to unlock the locking tab on the ribbon cable connector, then gently disconnect the ribbon cable.
      Ask FixBot
Connor Bassolino
27,057 Reputation
125 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 47
Past 30 Days: 243
All Time: 987
