Disassembling 8BitDo Pro 2 Wired Joystick Board
    1. Disassembling 8BitDo Pro 2 Wired Joystick Board, Remove R2 and L2 pads: step 1, image 1 of 2 Disassembling 8BitDo Pro 2 Wired Joystick Board, Remove R2 and L2 pads: step 1, image 2 of 2
      • Remove both pads by pushing them up.
      Ask FixBot
    2. Disassembling 8BitDo Pro 2 Wired Joystick Board, Remove T6 Screws: step 2, image 1 of 1
      • Remove both Torx T6 screws from the back.
      Ask FixBot
    3. Disassembling 8BitDo Pro 2 Wired Joystick Board, Open the controller: step 3, image 1 of 3 Disassembling 8BitDo Pro 2 Wired Joystick Board, Open the controller: step 3, image 2 of 3 Disassembling 8BitDo Pro 2 Wired Joystick Board, Open the controller: step 3, image 3 of 3
      • With an opening pick, detach the seven clips holding the faceplate. Start from the sides, towards the bottom.
      • Detach the remaining clips by carefully raising the faceplate away from the clips.
      • A flex cable joins both plates.
      • Move the faceplate to the side.
      Ask FixBot
    4. Disassembling 8BitDo Pro 2 Wired Joystick Board, Remove the flex cable: step 4, image 1 of 1
      • Push the sides of the connector away from it to free the cable.
      Ask FixBot
    5. Disassembling 8BitDo Pro 2 Wired Joystick Board, Remove the #0 screws: step 5, image 1 of 1
      • Remove the 8 screws using a Phillips #0 screwdriver.
      • You can remove the joystick caps by lifting them.
      Ask FixBot
    6. Disassembling 8BitDo Pro 2 Wired Joystick Board, Remove the board: step 6, image 1 of 2 Disassembling 8BitDo Pro 2 Wired Joystick Board, Remove the board: step 6, image 2 of 2
      • Slowly lift the board from the controller. Make sure to lift both rumble motors as well.
      Ask FixBot
Adrián
213 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 37
Past 30 Days: 201
All Time: 1,697
