Up to 20% off select tools
Dis/assembling Eye/Pupil Camera Housing
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
26
Past 30 Days:
111
All Time:
1,559
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 16
16 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Community-Contributed Guide
Tools
    1. Dis/assembling Eye/Pupil Camera Housing, Camera Housing: step 1, image 1 of 1
      • First: Eye Camera
      • Remove initial frame (crack off)
      Ask FixBot
    2. Dis/assembling Eye/Pupil Camera Housing: step 2, image 1 of 1
      • Remove 4 screws.
      Ask FixBot
    3. Dis/assembling Eye/Pupil Camera Housing: step 3, image 1 of 1
      • Remove cover to get to the PCB underneath
      Ask FixBot
    4. Dis/assembling Eye/Pupil Camera Housing: step 4, image 1 of 1
      • Remove two screws on the PCB.
      Ask FixBot
    5. Dis/assembling Eye/Pupil Camera Housing: step 5, image 1 of 1
      • Remove PCB from the base plastic piece.
      Ask FixBot
    6. Dis/assembling Eye/Pupil Camera Housing: step 6, image 1 of 1
      • Break base plastic piece. Cutters work well. Be careful not to snip the wire attached to the PCB.
      Ask FixBot
    7. Dis/assembling Eye/Pupil Camera Housing: step 7, image 1 of 1
      • Black mold (from 3D printer) piece attaches to the PCB with 4 screws.
      Ask FixBot
    8. Dis/assembling Eye/Pupil Camera Housing: step 8, image 1 of 1
      • Completed assembly of the eye camera.
      Ask FixBot
    9. Dis/assembling Eye/Pupil Camera Housing, Pupil camera dis/assembly: step 9, image 1 of 1
      • Back of pupil camera is glued on. Remove with flat-head.
      Ask FixBot
    10. Dis/assembling Eye/Pupil Camera Housing: step 10, image 1 of 1
      • Remove the black frame on the front of the pupil camera.
      Ask FixBot
    11. Dis/assembling Eye/Pupil Camera Housing: step 11, image 1 of 2 Dis/assembling Eye/Pupil Camera Housing: step 11, image 2 of 2
      • Once frame is taken off the front, two screws need to be removed.
      Ask FixBot
    12. Dis/assembling Eye/Pupil Camera Housing: step 12, image 1 of 1
      • One screw removed from the back.
      Ask FixBot
    13. Dis/assembling Eye/Pupil Camera Housing: step 13, image 1 of 1
      • Front housing comes off once the screws are removed from the frame.
      • Twist out the silver microphone.
      Ask FixBot
    14. Dis/assembling Eye/Pupil Camera Housing: step 14, image 1 of 1
      • Pull off bottom stand until it breaks off.
      Ask FixBot
    15. Dis/assembling Eye/Pupil Camera Housing: step 15, image 1 of 2 Dis/assembling Eye/Pupil Camera Housing: step 15, image 2 of 2
      • Remove rubber/plastic piece from the bottom
      Ask FixBot
    16. Dis/assembling Eye/Pupil Camera Housing: step 16, image 1 of 1
      • Remove four screws from under the plastic tape (removed from last step).
      Ask FixBot
    17. Dis/assembling Eye/Pupil Camera Housing: step 17, image 1 of 2 Dis/assembling Eye/Pupil Camera Housing: step 17, image 2 of 2
      • Bottom pops off
      Ask FixBot
    18. Dis/assembling Eye/Pupil Camera Housing: step 18, image 1 of 2 Dis/assembling Eye/Pupil Camera Housing: step 18, image 2 of 2
      • Separate the metal frame from the plastic assembly.
      • Avoid the cables
      Ask FixBot
    19. Dis/assembling Eye/Pupil Camera Housing: step 19, image 1 of 1
      • Take out PCB from the plastic housing.
      Ask FixBot
    20. Dis/assembling Eye/Pupil Camera Housing: step 20, image 1 of 3 Dis/assembling Eye/Pupil Camera Housing: step 20, image 2 of 3 Dis/assembling Eye/Pupil Camera Housing: step 20, image 3 of 3
      • Remove the rest of the black plastic housing.
      Ask FixBot
    21. Dis/assembling Eye/Pupil Camera Housing: step 21, image 1 of 1
      • Black plastic housing removed
      Ask FixBot
    22. Dis/assembling Eye/Pupil Camera Housing: step 22, image 1 of 3 Dis/assembling Eye/Pupil Camera Housing: step 22, image 2 of 3 Dis/assembling Eye/Pupil Camera Housing: step 22, image 3 of 3
      • Continue removing the black plastic housing surrounding the inner PCB.
      Ask FixBot
    23. Dis/assembling Eye/Pupil Camera Housing: step 23, image 1 of 2 Dis/assembling Eye/Pupil Camera Housing: step 23, image 2 of 2
      • PCB removed from the black plastic housing.
      Ask FixBot
    24. Dis/assembling Eye/Pupil Camera Housing: step 24, image 1 of 1
      • Autofocus assembly.
      • Remove two screws from the bottom of the auto-focus PCB.
      Ask FixBot
    25. Dis/assembling Eye/Pupil Camera Housing: step 25, image 1 of 1
      • Unscrew the lens
      Ask FixBot
    26. Dis/assembling Eye/Pupil Camera Housing: step 26, image 1 of 2 Dis/assembling Eye/Pupil Camera Housing: step 26, image 2 of 2
      • Take out the IR filter by using a scalpel for pulling out the lens tape.
      Ask FixBot
    27. Dis/assembling Eye/Pupil Camera Housing: step 27, image 1 of 3 Dis/assembling Eye/Pupil Camera Housing: step 27, image 2 of 3 Dis/assembling Eye/Pupil Camera Housing: step 27, image 3 of 3
      • Comparison photos of completed autofocus assembly vs in-progress autofocus assembly
      Ask FixBot
    28. Dis/assembling Eye/Pupil Camera Housing: step 28, image 1 of 2 Dis/assembling Eye/Pupil Camera Housing: step 28, image 2 of 2
      • IR LEDs replaced by SMD LED
      • Soldering required here (at bottom of LED to remove).
      Ask FixBot
    29. Dis/assembling Eye/Pupil Camera Housing: step 29, image 1 of 1
      • SMD LED info: Thick black line is near the positive side of the LED
      • Dark side (dot) is positive side on LED.
      Ask FixBot
    30. Dis/assembling Eye/Pupil Camera Housing: step 30, image 1 of 3 Dis/assembling Eye/Pupil Camera Housing: step 30, image 2 of 3 Dis/assembling Eye/Pupil Camera Housing: step 30, image 3 of 3
      • Insert PCB into 3d-printed frame.
      Ask FixBot
    31. Dis/assembling Eye/Pupil Camera Housing: step 31, image 1 of 2 Dis/assembling Eye/Pupil Camera Housing: step 31, image 2 of 2
      • Completed assembly.
      • Sugru used for nose/head rest
      Ask FixBot
2 other people completed this guide.
Author
with
Silas
318 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 26
Past 30 Days: 111
All Time: 1,559
