Digitech XC- 5206 Dual Speaker Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
7
Past 30 Days:
46
All Time:
691
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Difficult
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
This guide will help users replace damaged or malfunctioning internal dual speakers on the Digitech XC-5206 Bluetooth speaker. Please refer to troubleshooting page before beginning replacement guide steps.
Tools
    1. Digitech XC- 5206 Dual Speaker Replacement, Dual Speaker: step 1, image 1 of 2 Digitech XC- 5206 Dual Speaker Replacement, Dual Speaker: step 1, image 2 of 2
      • Remove the front panel by forcefully placing the flat edge of the spudger in between the panel and the plastic housing.
      • Angle the spudger and use your fingers to pry the panel off.
      • You may need to use extra force.
      Ask FixBot
    2. Digitech XC- 5206 Dual Speaker Replacement: step 2, image 1 of 3 Digitech XC- 5206 Dual Speaker Replacement: step 2, image 2 of 3 Digitech XC- 5206 Dual Speaker Replacement: step 2, image 3 of 3
      • Unscrew all eight 14mm screws closest to the edges of the speaker by spinning a size PH2 screwdriver in a counterclockwise motion.
      • Dislodge face by holding speaker face down. Gently shake or tap front against table to fully remove face.
      • OR grab ahold of the silver tab to pull the speaker face out. This may require force.
      Ask FixBot
    3. Digitech XC- 5206 Dual Speaker Replacement: step 3, image 1 of 2 Digitech XC- 5206 Dual Speaker Replacement: step 3, image 2 of 2
      • Unscrew the eight 10mm screws closest to the center of the speakers by spinning a Phillips screwdriver with a PH2 bit in a counterclockwise motion.
      • Push speaker bulbs forward and out of slot.
      Ask FixBot
    4. Digitech XC- 5206 Dual Speaker Replacement: step 4, image 1 of 2 Digitech XC- 5206 Dual Speaker Replacement: step 4, image 2 of 2
      • Remove green (left) and red (right) wired connection to speaker bulb using a soldering station.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 46
All Time: 691
