Digital2 Platinum Pad 9 Volume Buttons Replacement
    1. Digital2 Platinum Pad 9 Volume Buttons Replacement, External Cover: step 1, image 1 of 1
      • Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
      Ask FixBot
    2. Digital2 Platinum Pad 9 Volume Buttons Replacement: step 2, image 1 of 2 Digital2 Platinum Pad 9 Volume Buttons Replacement: step 2, image 2 of 2
      • After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
      Ask FixBot
    3. Digital2 Platinum Pad 9 Volume Buttons Replacement: step 3, image 1 of 2 Digital2 Platinum Pad 9 Volume Buttons Replacement: step 3, image 2 of 2
      • Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
      • Then just remove the backing.
      Ask FixBot
    1. Digital2 Platinum Pad 9 Volume Buttons Replacement, Volume Buttons: step 4, image 1 of 1
      • You can locate the volume buttons on one of the longer sides of the tablet.
      Ask FixBot
    2. Digital2 Platinum Pad 9 Volume Buttons Replacement: step 5, image 1 of 1
      • Lift up the ZIF connector that is attached to the volume buttons ribbon cable.
      Ask FixBot
    3. Digital2 Platinum Pad 9 Volume Buttons Replacement: step 6, image 1 of 1
      • Then remove the ribbon cable from the ZIF connector.
      Ask FixBot
    4. Digital2 Platinum Pad 9 Volume Buttons Replacement: step 7, image 1 of 1
      • Make sure to separate the volume button's cable from the cable connecting the motherboard to the screen
      Ask FixBot
    5. Digital2 Platinum Pad 9 Volume Buttons Replacement: step 8, image 1 of 2 Digital2 Platinum Pad 9 Volume Buttons Replacement: step 8, image 2 of 2
      Tool used on this step:
      Buy
      • Then use the precision tweezers to grab the volume buttons.
      • Pull until the buttons come out.
      Ask FixBot
David DeMeritt
637 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 21
All Time: 336
