Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement
    1. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement, External Cover: step 1, image 1 of 1
      • Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
      Ask FixBot
    2. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: step 2, image 1 of 2 Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: step 2, image 2 of 2
      • After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
      Ask FixBot
    3. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: step 3, image 1 of 2 Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: step 3, image 2 of 2
      • Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
      • Then just remove the backing.
      Ask FixBot
    1. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement, Front/Rear Facing Camera: step 4, image 1 of 1
      • The front/rear facing cameras are located in the corner of the device one is facing toward you and is black. The other is facing away so you will see the white backing.
      Ask FixBot
    2. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: step 5, image 1 of 2 Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: step 5, image 2 of 2
      • Use the plastic opening tool to pop up the cameras from their slot in the Tablet.
      • Then use your hand to lift up the cameras.
      • Make sure not to tear the ribbon cables.
      Ask FixBot
    3. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: step 6, image 1 of 1
      • Use a smaller plastic opening tool to lift up the ZIF connector in which the cameras are plugged into.
      Ask FixBot
    4. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: step 7, image 1 of 1
      • Finally remove the cameras.
      Ask FixBot
David DeMeritt
637 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 61
All Time: 425
