Digital2 Platinum Pad 9 External Cover Replacement
    1. Digital2 Platinum Pad 9 External Cover Replacement, External Cover: step 1, image 1 of 1
      • Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
      Ask FixBot
    2. Digital2 Platinum Pad 9 External Cover Replacement: step 2, image 1 of 2 Digital2 Platinum Pad 9 External Cover Replacement: step 2, image 2 of 2
      • After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
      Ask FixBot
    3. Digital2 Platinum Pad 9 External Cover Replacement: step 3, image 1 of 2 Digital2 Platinum Pad 9 External Cover Replacement: step 3, image 2 of 2
      • Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
      • Then just remove the backing.
      Ask FixBot
David DeMeritt
637 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 27
All Time: 593
