Up to 20% off select tools
Digital2 D2-912 Screen Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
89
All Time:
1,230
Comments: 4
1 comment on steps, 3 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Tools
Introduction
Go to step 1 ↓
We will be replacing the screen in the tablet by first taking the tablet apart. Dropping the tablet with no cover or protection is likely to result in a cracked screen.
    1. Digital2 D2-912 Screen Replacement, External Cover: step 1, image 1 of 1
      • Remove the two Phillips #00 screws from the bottom of the case.
      Ask FixBot
    2. Digital2 D2-912 Screen Replacement: step 2, image 1 of 2 Digital2 D2-912 Screen Replacement: step 2, image 2 of 2
      • Wedge the opening tool in the space between the back and the front of the tablet.
      • Carefully work your way around the perimeter, wedging the opening tool between the front and back of the tablet.
      • When the back of the tablet is mostly detached from the front, carefully pull it away completely.
      Ask FixBot
    1. Digital2 D2-912 Screen Replacement, Screen: step 3, image 1 of 1
      • Be sure to remove the yellow tape that is holding the components down.
      • Locate the two yellow ribbon cables and carefully remove by lifting the black tab connectors forward and slide out ribbon.
      • When all components are unsecured, you will be able to remove the battery, motherboard, camera, and speaker out of the way.
      Ask FixBot
    2. Digital2 D2-912 Screen Replacement: step 4, image 1 of 1
      • Using the metal spudger, pry the display from the screen.
      Ask FixBot
    3. Digital2 D2-912 Screen Replacement: step 5, image 1 of 1
      • The screen is now ready to be replaced by the new one
      Ask FixBot
Author
with
Lindsay Richardson
394 Reputation
3 Guides authored
IUPUI, Team 1-1, Harley Fall 2015 Member of IUPUI, Team 1-1, Harley Fall 2015
IUPUI-HARLEY-F15S1G1
4 Members
72 Guides authored
3 Guide Comments
Dear Lindsay,
thank you for the guide how to open up that little thing!
Apparently I have fried it after I had mislaid the charger and used my
universal charger without checking the voltage: 8 instead of 5... If only
I had used my reading glasses.
Is there something like a fuse that I could repair/exchange?
Thank you for your help!
Respectfully,
Wolfgang
Dr. Wolfgang Mohr - Reply Share
Thanks for the help, I am just curious where I can get the new screen, I believe that the front glass is fine but the actual display I am pretty sure is not.
Super Manny - Reply Share
This website right here. Straight trash,basically So you have a broken tablet. You come to the website to get help to replace it. And it's no help at all. This is what I think about this hot mass right here
Rocia Patrick - Reply Share
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 89
All Time: 1,230
