Digital2 D2-861G Motherboard Replacement
    1. Digital2 D2-861G Motherboard Replacement, Motherboards: step 1, image 1 of 1
      • Working on your device while powered on may result in electric shock. Make sure to unplug and power down your device before you begin.
      • Place your device on a soft cloth to avoid scratching the screen.
      • Flip your device over so back panel is facing upwards.
      Ask FixBot
    2. Digital2 D2-861G Motherboard Replacement: step 2, image 1 of 1
      • Do not use a lot of force as it can break the clips or the back panel.
      • Insert spudger in the slot below the micro SD card.
      • You should hear clips releasing as you pry along the edges.
      • With the spudger tool, run along the edges of the backing undoing 20 plastic clips.
      Ask FixBot
    3. Digital2 D2-861G Motherboard Replacement: step 3, image 1 of 3 Digital2 D2-861G Motherboard Replacement: step 3, image 2 of 3 Digital2 D2-861G Motherboard Replacement: step 3, image 3 of 3
      • Locate the gold colored ZIF (Zero insertion force) connector and disconnect it from the motherboard.
      • To disconnect the ZIF connector, go under the black tab and lift up. Then pull the connector out.
      • Locate the bundled cable connector and disconnect it by simply pulling it gently or using a spudger.
      • Disconnecting the bundled cable connector helps avoid short circuiting anything on the device.
      Ask FixBot
    4. Digital2 D2-861G Motherboard Replacement: step 4, image 1 of 3 Digital2 D2-861G Motherboard Replacement: step 4, image 2 of 3 Digital2 D2-861G Motherboard Replacement: step 4, image 3 of 3
      • Make sure to have your magnetic board to hold your screws.
      • Remove two 3.51mm screws that are located on the top corners with your Phillips #00 screwdriver.
      • Next, unplug the ZIF connector by going under the black tab and simply lift up.
      • Slide the connector out with the pointed side of the spudger.
      Ask FixBot
    5. Digital2 D2-861G Motherboard Replacement: step 5, image 1 of 3 Digital2 D2-861G Motherboard Replacement: step 5, image 2 of 3 Digital2 D2-861G Motherboard Replacement: step 5, image 3 of 3
      • This step is optional if you want to remove the metal casing.
      • Insert the pointed side of the spudger in the corner and gently lift.
      • Once one side is lifted, use your fingers and with little force, lift up to remove the case.
      Ask FixBot
    6. Digital2 D2-861G Motherboard Replacement: step 6, image 1 of 1
      • Use little force or else you risk breaking the motherboard.
      • Watch out for the ZIF connector!
      • There is a white clip holding the motherboard.
      • To remove the motherboard, grab the component on the top left and gently lift while pushing or pulling to the right.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 21
All Time: 703
