Digital2 7" Tablet D2-713G GN Battery Replacement
    1. Digital2 7" Tablet D2-713G GN Battery Replacement, Battery: step 1, image 1 of 3 Digital2 7" Tablet D2-713G GN Battery Replacement, Battery: step 1, image 2 of 3 Digital2 7" Tablet D2-713G GN Battery Replacement, Battery: step 1, image 3 of 3
      • Insert the prying tool into the crack between the case and the display border found to the right of the charging port.
      • Continue to pry around the case.
      • After prying all around the device, separate the back cover from the display.
      Ask FixBot
    2. Digital2 7" Tablet D2-713G GN Battery Replacement: step 2, image 1 of 3 Digital2 7" Tablet D2-713G GN Battery Replacement: step 2, image 2 of 3 Digital2 7" Tablet D2-713G GN Battery Replacement: step 2, image 3 of 3
      • Above the battery, peel back the yellow tape so the battery cables are not held in place.
      • Do not completely remove the tape.
      Ask FixBot
    3. Digital2 7" Tablet D2-713G GN Battery Replacement: step 3, image 1 of 2 Digital2 7" Tablet D2-713G GN Battery Replacement: step 3, image 2 of 2
      • Use the spudger to pry underneath the battery and remove it.
      Ask FixBot
    4. Digital2 7" Tablet D2-713G GN Battery Replacement: step 4, image 1 of 1
      • Use the soldering iron to remove the cables from the circuit board.
      • Solder the new battery cables onto the circuit board.
      Ask FixBot
Miguel A Rodriguez
590 Reputation
4 Guides authored
Gateway, Team 1-6, Johnson Fall 2014 Member of Gateway, Team 1-6, Johnson Fall 2014
GCC-JOHNSON-F14S1G6
2 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 95
All Time: 4,334
