Digital AV Mixer WJ-AVE5 Disassembly
  1. Digital AV Mixer WJ-AVE5 Disassembly, View From Above: step 1, image 1 of 1
    • This is a Digital AV Mixer (Model WJ-AVE5) and we'll be covering the steps required to remove the top-board and controls.
    Ask FixBot
  2. Digital AV Mixer WJ-AVE5 Disassembly, The Knob: step 2, image 1 of 1
    • Unscrew the stick extension by turning it left. If you're running into resistance try holding the shaft of the stick, during previous service this extension may have had Loctite applied to stock it from loosening.
    Ask FixBot
  3. Digital AV Mixer WJ-AVE5 Disassembly, View From Below: step 3, image 1 of 3 Digital AV Mixer WJ-AVE5 Disassembly, View From Below: step 3, image 2 of 3 Digital AV Mixer WJ-AVE5 Disassembly, View From Below: step 3, image 3 of 3
    • This is the bottom of your Digital Mixer. There are Seventeen (17) screws that need to move forward.
    Ask FixBot
  4. Digital AV Mixer WJ-AVE5 Disassembly, The Pizza Box Open: step 4, image 1 of 2 Digital AV Mixer WJ-AVE5 Disassembly, The Pizza Box Open: step 4, image 2 of 2
    • Now the top-board should pivot up like a pizza-box allowing access to both the solder side of the top-board and the EMI Shielding for both the Primary Power Board and the Primary Control Board.
    Ask FixBot
  5. Digital AV Mixer WJ-AVE5 Disassembly, Solder-Side of Top-Board: step 5, image 1 of 1
    • Shot of the solder-side of the top-board for reference on connector locations, cable routing, and component reference.
    Ask FixBot
  6. Digital AV Mixer WJ-AVE5 Disassembly: step 6, image 1 of 1
    • Shot of the bottom-board for reference on connector locations, cable routing, and component reference.
    Ask FixBot
3 other people completed this guide.
Driftless Repair
820 Reputation
3 Guides authored
Bridgetown Repair Member of Bridgetown Repair
Business
2 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 35
All Time: 1,207
