Digiland DL1168A Rear Case Replacement
    1. Digiland DL1168A Rear Case Replacement, Rear Case: step 1, image 1 of 1
      • Using an opening tool, begin softly prying open device by first inserting it in between the front and back panels.
      • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
      Ask FixBot
    2. Digiland DL1168A Rear Case Replacement: step 2, image 1 of 2 Digiland DL1168A Rear Case Replacement: step 2, image 2 of 2
      • Carefully lift back panel away from the body of the device.
      • Be gentle when lifting the back panel. The speaker wires are still connected to both the front and back panel.
      Ask FixBot
    3. Digiland DL1168A Rear Case Replacement: step 3, image 1 of 2 Digiland DL1168A Rear Case Replacement: step 3, image 2 of 2
      • Desolder the four wires connecting the rear case to the motherboard.
      • Disconnect the wires from the motherboard.
      • Remove the rear case from the device.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 28
All Time: 387
