Digiland DL1168A Battery Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
58
All Time:
740
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
If your Digiland DL1168A tablet often overheats, charges slowly, shuts down suddenly, or doesn't hold a charge as well as it used to, it may be time to open it up and replace the battery. This is not a hard repair, but you will need an iFixit opening tool and a soldering iron (see Tools list).
Be safe while soldering: work on a fire-resistant surface in a well-ventilated area, wear fire-resistant clothes that cover your arms and legs, and use eye protection.
Work carefully, as the battery is held in place with strong glue that is difficult to get off. If the battery is swollen, be extremely careful, as damaging a swollen battery could release toxic gas and/or start a fire.
Always use caution when working with electrical components. Shut the tablet completely off before starting, back up your data, and have a fireproof container (such as a bucket of sand) on hand to safely store the dead battery.
Never throw a battery away with general waste. Find a recycling center or electronic retailer who can dispose of them safely.
Tools
    1. Digiland DL1168A Battery Replacement, Rear Case: step 1, image 1 of 1
      • Using an opening tool, begin softly prying open device by first inserting it in between the front and back panels.
      • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
      Ask FixBot
    2. Digiland DL1168A Battery Replacement: step 2, image 1 of 2 Digiland DL1168A Battery Replacement: step 2, image 2 of 2
      • Carefully lift back panel away from the body of the device.
      • Be gentle when lifting the back panel. The speaker wires are still connected to both the front and back panel.
      Ask FixBot
    3. Digiland DL1168A Battery Replacement: step 3, image 1 of 2 Digiland DL1168A Battery Replacement: step 3, image 2 of 2
      • Desolder the four wires connecting the rear case to the motherboard.
      • Disconnect the wires from the motherboard.
      • Remove the rear case from the device.
      Ask FixBot
    1. Digiland DL1168A Battery Replacement, Battery: step 4, image 1 of 3 Digiland DL1168A Battery Replacement, Battery: step 4, image 2 of 3 Digiland DL1168A Battery Replacement, Battery: step 4, image 3 of 3
      • Desolder the three positive, negative, and neutral red, black, and white wires from the motherboard that are connected to the battery.
      • The soldering tool is hot, and will burn. Follow this link for instructions on How To Solder and Desolder Connections.
      Ask FixBot
    2. Digiland DL1168A Battery Replacement: step 5, image 1 of 2 Digiland DL1168A Battery Replacement: step 5, image 2 of 2
      • Using an opening tool, separate the battery from the tablet.
      • Follow the edge of the battery to loosen the glue.
      Ask FixBot
    3. Digiland DL1168A Battery Replacement: step 6, image 1 of 3 Digiland DL1168A Battery Replacement: step 6, image 2 of 3 Digiland DL1168A Battery Replacement: step 6, image 3 of 3
      • Once the glue is loosened, pry the battery away from the screen.
      • Pulling on the battery may cause you to bend the battery. Bending the battery could cause it to break open. Battery fumes are toxic and unsafe.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 58
All Time: 740
