DigiTech RP70 Motherboard Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
66
All Time:
1,463
Comments: 4
4 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 - 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
If you need to replace your motherboard or inspect its solder connections, use this guide to remove it. Removing the motherboard will be necessary if you want to replace any other component of the device.
Tools
    1. DigiTech RP70 Motherboard Replacement, Motherboard: step 1, image 1 of 2 DigiTech RP70 Motherboard Replacement, Motherboard: step 1, image 2 of 2
      • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
      • Remove the four 8mm Phillips #0 screws located on the back panel.
      Ask FixBot
    2. DigiTech RP70 Motherboard Replacement: step 2, image 1 of 2 DigiTech RP70 Motherboard Replacement: step 2, image 2 of 2
      • Remove the back panel to expose the motherboard.
      Ask FixBot
    3. DigiTech RP70 Motherboard Replacement: step 3, image 1 of 1
      • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
      Ask FixBot
    4. DigiTech RP70 Motherboard Replacement: step 4, image 1 of 1
      • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
      Ask FixBot
4 Guide Comments
My digitech rp 80 not work. How to get new motherboard
Thadevus - Reply Share
My digitecj rp 80 not working. No display no sound how to get new motherboard
Does anyone know where I can get the tone library push button/knob assy? Mine broke off.
Michael Adkins - Reply Share
Quiero comprar una estoy en Ecuador. Quiero comprar la moterboard
Lenin Omar Guerra Chango - Reply Share
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 66
All Time: 1,463
