DigiTech RP70 DC Power Connector Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
66
All Time:
706
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
If the DC power connector is broken this guide will teach you how to remove the broken component for replacement.
Tools
    1. DigiTech RP70 DC Power Connector Replacement, Motherboard: step 1, image 1 of 2 DigiTech RP70 DC Power Connector Replacement, Motherboard: step 1, image 2 of 2
      • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
      • Remove the four 8mm Phillips #0 screws located on the back panel.
      Ask FixBot
    2. DigiTech RP70 DC Power Connector Replacement: step 2, image 1 of 2 DigiTech RP70 DC Power Connector Replacement: step 2, image 2 of 2
      • Remove the back panel to expose the motherboard.
      Ask FixBot
    3. DigiTech RP70 DC Power Connector Replacement: step 3, image 1 of 1
      • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
      Ask FixBot
    4. DigiTech RP70 DC Power Connector Replacement: step 4, image 1 of 1
      • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
      Ask FixBot
    1. DigiTech RP70 DC Power Connector Replacement, DC Power Connector: step 5, image 1 of 1
      • Desolder the back of the motherboard where the power connector is located.
      Ask FixBot
1 Guide Comment
Later? I cant see to other
ISAAC SALAZAR - Reply Share
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 66
All Time: 706
