Up to 20% off select tools
DigiTech RP70 LED Light Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
11
Past 30 Days:
72
All Time:
750
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
If the LED light is broken, or dead, this guide will teach you how to remove the broken component for replacement.
    1. DigiTech RP70  LED Light Replacement, Motherboard: step 1, image 1 of 2 DigiTech RP70  LED Light Replacement, Motherboard: step 1, image 2 of 2
      • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
      • Remove the four 8mm Phillips #0 screws located on the back panel.
      Ask FixBot
    2. DigiTech RP70  LED Light Replacement: step 2, image 1 of 2 DigiTech RP70  LED Light Replacement: step 2, image 2 of 2
      • Remove the back panel to expose the motherboard.
      Ask FixBot
    3. DigiTech RP70  LED Light Replacement: step 3, image 1 of 1
      • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
      Ask FixBot
    4. DigiTech RP70  LED Light Replacement: step 4, image 1 of 1
      • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
      Ask FixBot
    1. DigiTech RP70  LED Light Replacement, LED Light: step 5, image 1 of 1
      • Desolder the back of the motherboard where the LED light is located.
      Ask FixBot
Author
with
Elijah Smith
738 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 72
All Time: 750
