Up to 20% off select tools
DigiLand DL801W Screen Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
92
All Time:
3,407
Comments: 3
3 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes
Difficulty: Moderate
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Tools
Introduction
Go to step 1 ↓
Be careful as you follow, and complete the steps listed in this guide. If a component is not coming out smoothly, make sure that all screws that need to be removed were removed. As you're removing the Screen or operating near it, watch out for any flex cable to avoid damaging them.
    1. DigiLand DL801W Screen Replacement, Screen: step 1, image 1 of 1
      • Before opening your DigiLand Tablet, ensure that the MicroSD card is removed.
      • Hold the tablet in one hand (not your primary hand) so that the bottom edge of the tablet is facing you and the back of the tablet is facing up.
      • Using a blue plastic opening tool, gently insert the tool between the back panel and the main body.
      • Going around the edge of the tablet, gently pry open the back panel. As you go around, you will hear a click.
      Ask FixBot
    2. DigiLand DL801W Screen Replacement: step 2, image 1 of 1
      • Once the back panel has been removed, it is best to set it aside in a safe location.
      • By using the J000 screwdriver, remove the 10 screws from the back. When the tablet is oriented like the picture, there are 6 screws to the left and 4 screws to the right. Set aside the screws in a safe place for re-installation.
      Ask FixBot
    3. DigiLand DL801W Screen Replacement: step 3, image 1 of 3 DigiLand DL801W Screen Replacement: step 3, image 2 of 3 DigiLand DL801W Screen Replacement: step 3, image 3 of 3
      • Disconnect the any wires that are connected to the motherboard.
      • Be careful not to damage any of the wires. If damaged, the tablet may not work correctly after repairing.
      Ask FixBot
    4. DigiLand DL801W Screen Replacement: step 4, image 1 of 1
      • Make sure not to damage the motherboard and components.
      • After removing all of the screws and disconnect any wires, use the blue plastic opening tool and starting from the bottom near the battery, carefully lift the back metal plate and motherboard out. Set aside in a secure place.
      Ask FixBot
    5. DigiLand DL801W Screen Replacement: step 5, image 1 of 1
      • After removing the motherboard, remove the LCD screen.
      • There are tabs around the LCD screen. Use the spudger to help remove.
      Ask FixBot
    6. DigiLand DL801W Screen Replacement: step 6, image 1 of 1
      • After removing the LCD screen, you should have four main components: The back cover, the motherboard and bracket, the LCD screen, and the front cover.
      • The screen is connected to the front cover. Carefully remove the cracked screen. The screen is connected by an adhesive.
      Ask FixBot
6 other people completed this guide.
Author
with
Preston Bremer
265 Reputation
1 Guide authored
IUPUI, Team 3-4, Harley Fall 2015 Member of IUPUI, Team 3-4, Harley Fall 2015
IUPUI-HARLEY-F15S3G4
4 Members
60 Guides authored
3 Guide Comments
I can't find a replacement lcd screen mine has the rainbow colored liquid marks on the lcd and there's lines going across the screen i have the digiland model# DL801W 8" Windows 10 tablet
eachespeaches - Reply Share
Yes Amazon supposedly has them for $19. I need one myself as it is cracked. The protection & cover not protect it.
Lilian Reitor - Reply Share
Where can i find a replacement lcd display screen for digiland DL801W i do not need the digitizer i just need the inner lcd screen
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 92
All Time: 3,407
