DigiLand DL801W Microphone Replacement
    1. DigiLand DL801W Microphone Replacement, Microphone: step 1, image 1 of 1
      • Please be aware that removing the back panel from the tablet could cause damage to the back or front panel.
      • Before opening your DigiLand Tablet, ensure that the MicroSD card is removed.
      • Hold the tablet in one hand (not your primary hand) so that the bottom edge of the tablet is facing you and the back of the tablet is facing up.
      • Using a blue plastic opening tool, gently insert the tool between the back panel and the main body.
      • Going around the edge of the tablet, gently pry open the back panel. As you go around, you will hear a click.
      Ask FixBot
    2. DigiLand DL801W Microphone Replacement: step 2, image 1 of 1
      • Using the black spudger, insert the point underneath the red and black wires. Gently lift the microphone out of its socket.
      • Where the red and black wires connect to the motherboard, use a soldering iron to remove the defective microphone.
      • If you have removed the microphone and cannot remember which wire went where, don't worry. The wire terminals on the motherboard are marked with a " + " and " - " sign.
      Ask FixBot
Travis Mangum
572 Reputation
4 Guides authored
IUPUI, Team 3-4, Harley Fall 2015 Member of IUPUI, Team 3-4, Harley Fall 2015
IUPUI-HARLEY-F15S3G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 32
All Time: 694
