DigiLand DL8006 Speaker Replacement
    1. DigiLand DL8006 Speaker Replacement, Speaker: step 1, image 1 of 1
      • Begin by opening the device around its edge using the iFixit opening tool.
      Ask FixBot
    2. DigiLand DL8006 Speaker Replacement: step 2, image 1 of 2 DigiLand DL8006 Speaker Replacement: step 2, image 2 of 2
      • Remove the metallic tape that covers the lower section of the battery.
      Ask FixBot
    3. DigiLand DL8006 Speaker Replacement: step 3, image 1 of 2 DigiLand DL8006 Speaker Replacement: step 3, image 2 of 2
      • Remove the three battery screws using a Phillips #0 screwdriver.
      Ask FixBot
    4. DigiLand DL8006 Speaker Replacement: step 4, image 1 of 3 DigiLand DL8006 Speaker Replacement: step 4, image 2 of 3 DigiLand DL8006 Speaker Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Pop up the locking tab of the ZIF connector using tweezers, and carefully pull the cable out from the motherboard.
      • Make sure the ribbon passes under the microphone wiring to avoid damage to the components.
      • Remove the lower section of the ribbon cable repeating the previous bullet.
      Ask FixBot
    5. DigiLand DL8006 Speaker Replacement: step 5, image 1 of 1
      • Remove the battery from the phone using the iFixit opening tool or the spudger.
      Ask FixBot
    6. DigiLand DL8006 Speaker Replacement: step 6, image 1 of 2 DigiLand DL8006 Speaker Replacement: step 6, image 2 of 2
      • Finally, remove the speaker from the tablet using the spudger.
      • In this image, a screwdriver was used to pry the speaker from its housing. You should use an ESD-safe tool to avoid causing damage to your device.
      Ask FixBot
Alec Trela
327 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 13
Past 7 Days: 14
Past 30 Days: 27
All Time: 405
