DigiLand DL8006 Motherboard Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
52
All Time:
570
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Introduction
Go to step 1 ↓
This guide will demonstrate how to replace to the DigiLand DL8006's motherboard. If your device is is experiencing frequent freezes and system lockups, and you have determined that it is not the fault of the RAM, power supply, or CPU, you may need to replace your motherboard. Make sure that you save your data on a separate device, as all the locally stored date will be removed when your motherboard is replaced.
Parts
Tools
    1. DigiLand DL8006 Motherboard Replacement, Motherboard: step 1, image 1 of 2 DigiLand DL8006 Motherboard Replacement, Motherboard: step 1, image 2 of 2
      • Remove the backing of the tablet to reveal the internal components using a plastic opening tool.
      Ask FixBot
    2. DigiLand DL8006 Motherboard Replacement: step 2, image 1 of 1
      • Peel back the metallic tape connecting the motherboard to the tablet body with your fingers.
      Ask FixBot
    3. DigiLand DL8006 Motherboard Replacement: step 3, image 1 of 3 DigiLand DL8006 Motherboard Replacement: step 3, image 2 of 3 DigiLand DL8006 Motherboard Replacement: step 3, image 3 of 3
      • Remove the battery plug from the motherboard.
      • Fingers may be used to gently wiggle the connector out if it becomes stuck.
      • If battery wires are under the ribbon, Do Step #4 first.
      Ask FixBot
    4. DigiLand DL8006 Motherboard Replacement: step 4, image 1 of 2 DigiLand DL8006 Motherboard Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Opening the locking tab of the ZIF connector and carefully remove the upper section of the ribbon cable from the motherboard using tweezers.
      Ask FixBot
    5. DigiLand DL8006 Motherboard Replacement: step 5, image 1 of 2 DigiLand DL8006 Motherboard Replacement: step 5, image 2 of 2
      • Disconnect the three remaining ribbons by opening the locking tabs of the ZIF connectors and gently pulling the cables out.
      • Use tweezers to manipulate the connectors and ribbons to prevent damage.
      Ask FixBot
    6. DigiLand DL8006 Motherboard Replacement: step 6, image 1 of 3 DigiLand DL8006 Motherboard Replacement: step 6, image 2 of 3 DigiLand DL8006 Motherboard Replacement: step 6, image 3 of 3
      • Remove the 3 mounting screws from the motherboard with a Phillips #0 screwdriver.
      • One of the screws is located under a ribbon. You will need to gently peel back the cable to access it (see image 3).
      Ask FixBot
    7. DigiLand DL8006 Motherboard Replacement: step 7, image 1 of 1
      • Gently remove the motherboard from the case.
      Ask FixBot
Alec Trela
327 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 52
All Time: 570
