Up to 20% off select tools
DigiLand DL718M Screen Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
64
All Time:
860
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Difficult
Needs More Images
A few more images would make this guide's procedures crystal clear.
Tools
Introduction
Go to step 1 ↓
If your Digiland DL718M tablet has a damaged or unresponsive screen, use this guide to replace the screen of the device.
If you are considering replacing your screen because of unresponsiveness, refer to the DigiLand DL718M Troubleshooting page to find out what could be causing this problem and if it can be fixed without replacing the screen.
This process requires you to remove the back panel of the device and thus expose the motherboard. Be careful when working with an exposed motherboard as you could damage it, if it comes into contact with moisture. It is motion-sensitive, and small aspects can be easily jostled out of place.
Before you begin, make sure to power the tablet off completely and disconnect it from any external power source.
    1. DigiLand DL718M Screen Replacement, Back Panel: step 1, image 1 of 1
      • Remove back panel by wedging the iFixit opening tool on all four sides of the device.
      Ask FixBot
    1. DigiLand DL718M Screen Replacement, Screen: step 2, image 1 of 1
      • Remove two silver Phillips #0 screws along the bottom of the internal panel.
      Ask FixBot
    2. DigiLand DL718M Screen Replacement: step 3, image 1 of 1
      • Remove the ribbon in the bottom left corner of the motherboard by lifting the black tab and sliding the ribbon out from the slot underneath the black tab.
      Ask FixBot
    3. DigiLand DL718M Screen Replacement: step 4, image 1 of 1
      • Remove the small, circular microphone on the left side of the device by sliding it out of its slot using an opening tool.
      Ask FixBot
    4. DigiLand DL718M Screen Replacement: step 5, image 1 of 1
      • Remove the front-facing camera in the top left corner of the device by sliding it out of its slot using an opening tool.
      Ask FixBot
    5. DigiLand DL718M Screen Replacement: step 6, image 1 of 1
      • Remove the three black Phillips #0 screws along the left side of the motherboard.
      Ask FixBot
    6. DigiLand DL718M Screen Replacement: step 7, image 1 of 1
      • Detach the black tape and the wire from the right side of the screen.
      Ask FixBot
    7. DigiLand DL718M Screen Replacement: step 8, image 1 of 1
      • Remove the rear-facing camera by prying it off of the back side of the screen using the an opening tool.
      Ask FixBot
    8. DigiLand DL718M Screen Replacement: step 9, image 1 of 1
      • Lift the motherboard and remove it from the device using an opening tool.
      • If there is any tape on the device that prohibits you from doing so, remove the tape.
      Ask FixBot
    9. DigiLand DL718M Screen Replacement: step 10, image 1 of 1
      • Remove the ribbon above the battery by lifting the black tab and sliding the ribbon out from the slot underneath the black tab using an opening tool.
      Ask FixBot
    10. DigiLand DL718M Screen Replacement: step 11, image 1 of 1
      • Pry the battery off of the back of the screen by wedging the iFixit opening tool underneath.
      Ask FixBot
    11. DigiLand DL718M Screen Replacement: step 12, image 1 of 2 DigiLand DL718M Screen Replacement: step 12, image 2 of 2
      • Lift the screen from the plastic casing.
      Ask FixBot
Author
with
Alayna Knarian
734 Reputation
6 Guides authored
1 Guide Comment
What happen after? How remove the LCD screen? ……..INCOMPLETE
jrtu2001 - Reply Share
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 64
All Time: 860
