DigiLand DL701Q Battery Replacement
Views: 5.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
90
All Time:
5,787
Comments: 4
4 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 9 - 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will instruct the user how to remove the back case and how to replace the battery. This step is usually taken when a battery needs to be replaced.
Tools
    1. DigiLand DL701Q Battery Replacement, Back Case: step 1, image 1 of 3 DigiLand DL701Q Battery Replacement, Back Case: step 1, image 2 of 3 DigiLand DL701Q Battery Replacement, Back Case: step 1, image 3 of 3
      • Make sure your device is turned off.
      • Hold the device firmly, in landscape view.
      • Locate the crevice that separates the front cover from the back cover. Then hold the plastic opening tool and insert the wedge portion of the tool into the crevice.
      • Some force may need to be applied and there may be a cracking sound. This is normal.
      • Slowly slide the wedge portion of the plastic opening tool while applying some upward force around the device until the back cover is completely loose.
      • Only apply enough force to loosen the back cover. Excessive force may damage the screen.
      Ask FixBot
    2. DigiLand DL701Q Battery Replacement: step 2, image 1 of 3 DigiLand DL701Q Battery Replacement: step 2, image 2 of 3 DigiLand DL701Q Battery Replacement: step 2, image 3 of 3
      • Place the screen in the palm of your hand and then with your other hand carefully grab the case and remove the cover like flipping the page of a book.
      • Lay the device down and notice that the speaker will be attached to the back cover with a wire. Carefully lift the speaker upward from the back cover and place it near the battery.
      • The speaker may be glued in so treat with care and remove the speaker by gently moving your finger around it and lifting up.
      Ask FixBot
    1. DigiLand DL701Q Battery Replacement, Battery: step 3, image 1 of 3 DigiLand DL701Q Battery Replacement, Battery: step 3, image 2 of 3 DigiLand DL701Q Battery Replacement, Battery: step 3, image 3 of 3
      • Lay device flat on the table.
      • Firmly grip the device on the edges. Take the wedge portion of the spudger tool and push in between the battery and the screen with force. Begin pushing the spudger with the wedge underneath the battery all the way around in order to break the glue.
      • Repeat this step pushing further across and underneath until the battery is loose.
      • The battery is heavily glued to the screen and much force may be needed to break the glued bond.
      Ask FixBot
    2. DigiLand DL701Q Battery Replacement: step 4, image 1 of 3 DigiLand DL701Q Battery Replacement: step 4, image 2 of 3 DigiLand DL701Q Battery Replacement: step 4, image 3 of 3
      • Once the battery is loose slowly lift it up so you can get to the terminals as seen in the next picture.
      • Desolder the battery's connection terminals from the motherboard.
      • If you do not know how to desolder look at this soldering and desoldering guide
      • Remove the battery by pulling it out of the device.
      • In order to avoid damage to the device, the battery must be physically removed from the device before proceeding with any further repairs . Leaving a battery close to a device being worked on can be extremely hazardous. Leads can bump into the motherboard or into each other by accident causing damage to the device.
      Ask FixBot
5 other people completed this guide.
Jonathan Mysona
1,135 Reputation
7 Guides authored
Clemson, Team 6-1, Benson Spring 2016 Member of Clemson, Team 6-1, Benson Spring 2016
CLEM-BENSON-S16S6G1
3 Members
84 Guides authored
4 Guide Comments
How much is the battery
damonta1972 - Reply Share
I have a Dl1168A Digiland how much is a battery and where can I get one. I can’t recharge my laptop
plbooboo - Reply Share
Plbooboo@aol.com
Onde posso achar bateria DL701
Cida Bueno - Reply Share
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 90
All Time: 5,787
