DigiLand DL701Q Back Case Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
89
All Time:
1,406
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
This guide will show the user the first steps into opening their Digiland tablet and replacing the back of the case.
Tools
    1. DigiLand DL701Q Back Case Replacement, Back Case: step 1, image 1 of 3 DigiLand DL701Q Back Case Replacement, Back Case: step 1, image 2 of 3 DigiLand DL701Q Back Case Replacement, Back Case: step 1, image 3 of 3
      • Make sure your device is turned off.
      • Hold the device firmly, in landscape view.
      • Locate the crevice that separates the front cover from the back cover. Then hold the plastic opening tool and insert the wedge portion of the tool into the crevice.
      • Some force may need to be applied and there may be a cracking sound. This is normal.
      • Slowly slide the wedge portion of the plastic opening tool while applying some upward force around the device until the back cover is completely loose.
      • Only apply enough force to loosen the back cover. Excessive force may damage the screen.
      Ask FixBot
    2. DigiLand DL701Q Back Case Replacement: step 2, image 1 of 3 DigiLand DL701Q Back Case Replacement: step 2, image 2 of 3 DigiLand DL701Q Back Case Replacement: step 2, image 3 of 3
      • Place the screen in the palm of your hand and then with your other hand carefully grab the case and remove the cover like flipping the page of a book.
      • Lay the device down and notice that the speaker will be attached to the back cover with a wire. Carefully lift the speaker upward from the back cover and place it near the battery.
      • The speaker may be glued in so treat with care and remove the speaker by gently moving your finger around it and lifting up.
      Ask FixBot
2 other people completed this guide.
Jonathan Mysona
1,135 Reputation
7 Guides authored
Clemson, Team 6-1, Benson Spring 2016 Member of Clemson, Team 6-1, Benson Spring 2016
CLEM-BENSON-S16S6G1
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 89
All Time: 1,406
