DigiLand DL700D Motherboard Replacement
    1. DigiLand DL700D Motherboard Replacement, Battery: step 1, image 1 of 3 DigiLand DL700D Motherboard Replacement, Battery: step 1, image 2 of 3 DigiLand DL700D Motherboard Replacement, Battery: step 1, image 3 of 3
      • Remove the device's back cover using the plastic opening tool.
      Ask FixBot
    2. DigiLand DL700D Motherboard Replacement: step 2, image 1 of 3 DigiLand DL700D Motherboard Replacement: step 2, image 2 of 3 DigiLand DL700D Motherboard Replacement: step 2, image 3 of 3
      • Remove the three pieces of adhesive placed over the edges of the battery.
      Ask FixBot
    3. DigiLand DL700D Motherboard Replacement: step 3, image 1 of 1
      • Remove the wifi antenna from the bottom of the battery.
      Ask FixBot
    4. DigiLand DL700D Motherboard Replacement: step 4, image 1 of 3 DigiLand DL700D Motherboard Replacement: step 4, image 2 of 3 DigiLand DL700D Motherboard Replacement: step 4, image 3 of 3
      • Heat up the soldering iron, proceed to desolder and remove the battery connections.
      Ask FixBot
    5. DigiLand DL700D Motherboard Replacement: step 5, image 1 of 3 DigiLand DL700D Motherboard Replacement: step 5, image 2 of 3 DigiLand DL700D Motherboard Replacement: step 5, image 3 of 3
      • Remove the battery from the casing using a nylon spudger.
      • Be careful not to puncture the battery casing.
      • Carefully peel the battery free from the casing.
      Ask FixBot
    1. DigiLand DL700D Motherboard Replacement, Motherboard: step 6, image 1 of 1
      • Desolder the WiFi antenna from the motherboard.
      Ask FixBot
    2. DigiLand DL700D Motherboard Replacement: step 7, image 1 of 3 DigiLand DL700D Motherboard Replacement: step 7, image 2 of 3 DigiLand DL700D Motherboard Replacement: step 7, image 3 of 3
      • Remove 3 ribbon cables attached to the motherboard by lifting the plastic retainer, then pulling the cable out.
      Ask FixBot
    3. DigiLand DL700D Motherboard Replacement: step 8, image 1 of 2 DigiLand DL700D Motherboard Replacement: step 8, image 2 of 2
      • Remove adhesive attaching the motherboard to the casing.
      Ask FixBot
    4. DigiLand DL700D Motherboard Replacement: step 9, image 1 of 3 DigiLand DL700D Motherboard Replacement: step 9, image 2 of 3 DigiLand DL700D Motherboard Replacement: step 9, image 3 of 3
      • Remove the three 2.5 mm Phillips #1 screws holding the motherboard to the case.
      Ask FixBot
    5. DigiLand DL700D Motherboard Replacement: step 10, image 1 of 3 DigiLand DL700D Motherboard Replacement: step 10, image 2 of 3 DigiLand DL700D Motherboard Replacement: step 10, image 3 of 3
      • Remove motherboard from the case and replace.
      Ask FixBot
To reassemble, follow these instructions in reverse order.
Justin Edwards
241 Reputation
2 Guides authored
IUPUI, Team S3-G4, Harley Spring 2018 Member of IUPUI, Team S3-G4, Harley Spring 2018
IUPUI-HARLEY-S18S3G4
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 24
All Time: 586
