DigiLand DL700D Battery Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
63
All Time:
726
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will cover the disassembly and replacement of the battery for the Digiland DL700D. The battery is attached to the mainboard by soldered wires, so some soldering will be required. We recommend reviewing iFixit's soldering guide here.
Parts
Tools
    1. DigiLand DL700D Battery Replacement, Battery: step 1, image 1 of 3 DigiLand DL700D Battery Replacement, Battery: step 1, image 2 of 3 DigiLand DL700D Battery Replacement, Battery: step 1, image 3 of 3
      • Remove the device's back cover using the plastic opening tool.
      Ask FixBot
    2. DigiLand DL700D Battery Replacement: step 2, image 1 of 3 DigiLand DL700D Battery Replacement: step 2, image 2 of 3 DigiLand DL700D Battery Replacement: step 2, image 3 of 3
      • Remove the three pieces of adhesive placed over the edges of the battery.
      Ask FixBot
    3. DigiLand DL700D Battery Replacement: step 3, image 1 of 1
      • Remove the wifi antenna from the bottom of the battery.
      Ask FixBot
    4. DigiLand DL700D Battery Replacement: step 4, image 1 of 3 DigiLand DL700D Battery Replacement: step 4, image 2 of 3 DigiLand DL700D Battery Replacement: step 4, image 3 of 3
      • Heat up the soldering iron, proceed to desolder and remove the battery connections.
      Ask FixBot
    5. DigiLand DL700D Battery Replacement: step 5, image 1 of 3 DigiLand DL700D Battery Replacement: step 5, image 2 of 3 DigiLand DL700D Battery Replacement: step 5, image 3 of 3
      • Remove the battery from the casing using a nylon spudger.
      • Be careful not to puncture the battery casing.
      • Carefully peel the battery free from the casing.
      Ask FixBot
To reassemble your device, follow instructions in the reverse order. Apply new Kapton Tape and apply extra solder as needed.
Justin Edwards
241 Reputation
2 Guides authored
IUPUI, Team S3-G4, Harley Spring 2018 Member of IUPUI, Team S3-G4, Harley Spring 2018
IUPUI-HARLEY-S18S3G4
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 63
All Time: 726
