DigiLand DL1010Q Rear Case Replacement
    1. DigiLand DL1010Q Rear Case Replacement, Rear Case: step 1, image 1 of 1
      • With a J00 Philips head screwdriver, unscrew the two 4mm black screws located at the bottom of the device.
      • Before disassembling your device, be sure it is powered off.
      Ask FixBot
    2. DigiLand DL1010Q Rear Case Replacement: step 2, image 1 of 2 DigiLand DL1010Q Rear Case Replacement: step 2, image 2 of 2
      • Using a plastic opening tool, begin softly prying open device by first inserting it in between the front and back panels.
      • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
      Ask FixBot
    3. DigiLand DL1010Q Rear Case Replacement: step 3, image 1 of 1
      • Carefully lift back panel away from the body of the device.
      • Speaker wires are connected to both the front and back panel.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 29
All Time: 787
