Up to 20% off select tools
DigMedia MusicStore Logic Board Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
58
All Time:
396
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
    1. DigMedia MusicStore Logic Board Replacement, Remove screws: step 1, image 1 of 1
      • Remove six Philips #2 screws from the bottom of the case.
      • REASSEMBLY CAUTION: To prevent thread stripping during reassembly, turn screws backwards slowly until you feel the screw thread drop into the original plastic thread, and only then, tighten screw normally but lightly - you're working with 20+ year-old plastics.
      Ask FixBot
    2. DigMedia MusicStore Logic Board Replacement, Disconnect top cover ribbon cable: step 2, image 1 of 1
      • Carefully fold the top and bottom open, revealing a ribbon cable connecting the two halves.
      • Unlock and disconnect the ribbon cable. Unlock by pulling the lock lever evenly on both sides, parallel to the board surface (not lift/pivot), in the direction of the ribbon cable.
      • When this ZIF (Zero Insertion Force) connector is properly unlocked, the ribbon cable should just fall right out of the socket (no need to pull with any strength).
      Ask FixBot
    3. DigMedia MusicStore Logic Board Replacement, Remove RF shield: step 3, image 1 of 2 DigMedia MusicStore Logic Board Replacement, Remove RF shield: step 3, image 2 of 2
      • Simply lift the RF shield off the unit.
      • When reinstalling, take note of the 6 fork-like interlocking clips around the edge of the shield, which should engage with the original positions.
      Ask FixBot
    1. DigMedia MusicStore Logic Board Replacement, CD-ROM cables and screws: step 4, image 1 of 1
      • Disconnect the digital audio connector (red) and the lid switch return connector (blue) from the logic board.
      • Unscrew four Philips #2 screws that secure the CD-ROM drive to the chassis.
      Ask FixBot
    2. DigMedia MusicStore Logic Board Replacement, Data and Power cables: step 5, image 1 of 1
      • Disconnect the large 40-pin IDE data connector and disconnect the 4-pin PC power connector from the CD-ROM drive.
      Ask FixBot
    3. DigMedia MusicStore Logic Board Replacement, Remove CD-ROM: step 6, image 1 of 1
      • Lift the CD-ROM drive out of the chassis.
      Ask FixBot
    1. DigMedia MusicStore Logic Board Replacement, Logic Board Screws: step 7, image 1 of 1
      • Remove 5 Philips #2 screws from the logic board (note: these are shorter than the previous screws)
      Ask FixBot
    2. DigMedia MusicStore Logic Board Replacement, Lid switch: step 8, image 1 of 1
      • Unplug the lid switch from the logic board. If the housing comes up with the connector (leaving only pins behind on the board), carefully separate the housing from the connector the two and push the housing back onto the pins in the original orientation.
      Ask FixBot
    3. DigMedia MusicStore Logic Board Replacement, Logic Board: step 9, image 1 of 1
      • Remove the logic board from the chassis.
      Ask FixBot
Author
with
Matt Falcon
2,827 Reputation
14 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 58
All Time: 396
