Dexcom G6 Receiver Battery Replacement
Views: 5.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
86
All Time:
5,336
Comments: 15
5 comments on steps, 10 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Difficult
Community-Contributed Guide
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Tools
    1. Dexcom G6 Receiver Battery Replacement, Display and Front Bezel: step 1, image 1 of 1
      • Unscrew the 6 Torx T5 screws from the back of the device
      Ask FixBot
    2. Dexcom G6 Receiver Battery Replacement: step 2, image 1 of 2 Dexcom G6 Receiver Battery Replacement: step 2, image 2 of 2
      • Use a spudger to lift up the screen assembly ribbon cable flap, then remove the ribbon cable.
      • Screen Information: Model AM0310R-04 Lot # NHT18080052
      Ask FixBot
    1. Dexcom G6 Receiver Battery Replacement, Charging Port: step 3, image 1 of 1
      • Using a spudger, unplug the Charging Port connector from the motherboard.
      Ask FixBot
    2. Dexcom G6 Receiver Battery Replacement: step 4, image 1 of 1
      • Remove the 2 silver Torx T5 screws holding the charging port down.
      Ask FixBot
    3. Dexcom G6 Receiver Battery Replacement: step 5, image 1 of 1
      • Remove the Charging Port Assembly from the motherboard.
      Ask FixBot
    1. Dexcom G6 Receiver Battery Replacement, Motherboard: step 6, image 1 of 1
      • Remove the silver Torx T5 screw holding the motherboard down.
      Ask FixBot
    2. Dexcom G6 Receiver Battery Replacement: step 7, image 1 of 2 Dexcom G6 Receiver Battery Replacement: step 7, image 2 of 2
      • Using a spudger, carefully remove the battery connector on the left side of the motherboard.
      Ask FixBot
    3. Dexcom G6 Receiver Battery Replacement: step 8, image 1 of 1
      • Using a spudger, carefully pry up the motherboard to remove it.
      Ask FixBot
    1. Dexcom G6 Receiver Battery Replacement, Battery: step 9, image 1 of 3 Dexcom G6 Receiver Battery Replacement, Battery: step 9, image 2 of 3 Dexcom G6 Receiver Battery Replacement, Battery: step 9, image 3 of 3
      • Use heat to soften the adhesive holding the battery down.
      Ask FixBot
      • Carefully use one or more opening picks to remove the adhesive holding the battery down, then remove the battery.
      Ask FixBot
4 other people completed this guide.
Andrew S
15,633 Reputation
8 Guides authored
10 Guide Comments
Where do you get battery? Dexcom won't sell it.
Richy - Reply Share
I'm not sure you can get this same battery somewhere else (I haven't performed a battery change myself, just took it apart for demonstration). I'll get back to you if I can figure out a way to use another battery.
Andrew S - Reply Share
@richy14330 The connector type is JST ACHR-03V.
Still looking ... Where to get a battery for this receiver? What type of battery is it ?
Julian Payne (Xfactor) - Reply Share
I don't think you can get a replacement battery for this device anywhere. It is a 950 mAh 06220 battery made by Jhih Hong Technology. The model number seems to be BAT000023 and the type is 1ICP4/44/59.
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 86
All Time: 5,336
