Dewalt Nailers DCN680D1 2018 Control Module Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
89
All Time:
1,715
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide shows how to remove and replace the control module for the Dewalt Nailers DCN680D1 2018.
The module is an all-in-one assembly, which includes the trigger mechanism, battery connector, and selector switch board.
Parts
Tools
    1. Dewalt Nailers DCN680D1 2018 Control Module Replacement, Remove the battery: step 1, image 1 of 3 Dewalt Nailers DCN680D1 2018 Control Module Replacement, Remove the battery: step 1, image 2 of 3 Dewalt Nailers DCN680D1 2018 Control Module Replacement, Remove the battery: step 1, image 3 of 3
      • Before you begin the repair, remove the battery from the device.
      Ask FixBot
    1. Dewalt Nailers DCN680D1 2018 Control Module Replacement, Loosen the outer housing: step 2, image 1 of 1
      • Remove the following screws securing the outer housing:
      • Twelve T10 screws
      • One 2.5 mm hex screw
      • Some of these screws are deeply recessed. You can use a flathead screwdriver to loosen these screws.
      Ask FixBot
    2. Dewalt Nailers DCN680D1 2018 Control Module Replacement, Remove the right housing: step 3, image 1 of 2 Dewalt Nailers DCN680D1 2018 Control Module Replacement, Remove the right housing: step 3, image 2 of 2
      • Lift and remove the right housing from the device.
      Ask FixBot
    3. Dewalt Nailers DCN680D1 2018 Control Module Replacement, Loosen the internal parts: step 4, image 1 of 2 Dewalt Nailers DCN680D1 2018 Control Module Replacement, Loosen the internal parts: step 4, image 2 of 2
      • Remove the lock button from its recess.
      • During reassembly, make sure that the button is properly seated and engages the trigger.
      Ask FixBot
    4. Dewalt Nailers DCN680D1 2018 Control Module Replacement: step 5, image 1 of 2 Dewalt Nailers DCN680D1 2018 Control Module Replacement: step 5, image 2 of 2
      • Slide the battery connector out of its recess.
      Ask FixBot
    5. Dewalt Nailers DCN680D1 2018 Control Module Replacement: step 6, image 1 of 3 Dewalt Nailers DCN680D1 2018 Control Module Replacement: step 6, image 2 of 3 Dewalt Nailers DCN680D1 2018 Control Module Replacement: step 6, image 3 of 3
      • Remove the switch board, switch, and spring from its housing recess.
      • During reassembly, use the third photo as a reference to help you set the components back in the housing.
      Ask FixBot
    6. Dewalt Nailers DCN680D1 2018 Control Module Replacement, Remove the left housing: step 7, image 1 of 3 Dewalt Nailers DCN680D1 2018 Control Module Replacement, Remove the left housing: step 7, image 2 of 3 Dewalt Nailers DCN680D1 2018 Control Module Replacement, Remove the left housing: step 7, image 3 of 3
      • Carefully flip the device over.
      • Remove the left housing from the device.
      Ask FixBot
    7. Dewalt Nailers DCN680D1 2018 Control Module Replacement: step 8, image 1 of 3 Dewalt Nailers DCN680D1 2018 Control Module Replacement: step 8, image 2 of 3 Dewalt Nailers DCN680D1 2018 Control Module Replacement: step 8, image 3 of 3
      • The spring under the release button has a tendency to fly out. Be careful not to lose the spring.
      • Carefully remove the release button from the device.
      • Remove the button spring from the device.
      Ask FixBot
    1. Dewalt Nailers DCN680D1 2018 Control Module Replacement, Remove the back support: step 9, image 1 of 2 Dewalt Nailers DCN680D1 2018 Control Module Replacement, Remove the back support: step 9, image 2 of 2
      • Use a T20 driver to remove the two screws (one on either side) securing the back support .
      Ask FixBot
    2. Dewalt Nailers DCN680D1 2018 Control Module Replacement: step 10, image 1 of 2 Dewalt Nailers DCN680D1 2018 Control Module Replacement: step 10, image 2 of 2
      • Loosen the two solenoid wires from the back support.
      Ask FixBot
    3. Dewalt Nailers DCN680D1 2018 Control Module Replacement: step 11, image 1 of 2 Dewalt Nailers DCN680D1 2018 Control Module Replacement: step 11, image 2 of 2
      • Pull the back support straight out of the device.
      Ask FixBot
    1. Dewalt Nailers DCN680D1 2018 Control Module Replacement, Disconnect the control module: step 12, image 1 of 2 Dewalt Nailers DCN680D1 2018 Control Module Replacement, Disconnect the control module: step 12, image 2 of 2
      • Use a T10 driver to remove the three screws securing the motor wires
      • Reassembly tip: The motor wires are color-coded. Be sure to reconnect the motor wires as shown in the photo.
      Ask FixBot
    2. Dewalt Nailers DCN680D1 2018 Control Module Replacement: step 13, image 1 of 2 Dewalt Nailers DCN680D1 2018 Control Module Replacement: step 13, image 2 of 2
      • Use a small flathead screwdriver to pry up and disconnect the sensor connector from the side of the motor.
      Ask FixBot
    3. Dewalt Nailers DCN680D1 2018 Control Module Replacement: step 14, image 1 of 2 Dewalt Nailers DCN680D1 2018 Control Module Replacement: step 14, image 2 of 2
      • Insert the point of a pick tool into the push-in connector's inlet hole, which has the control module wire plugged into it.
      • Make sure you choose the inlet that connects to the control module, not the solenoid.
      Ask FixBot
    4. Dewalt Nailers DCN680D1 2018 Control Module Replacement: step 15, image 1 of 2 Dewalt Nailers DCN680D1 2018 Control Module Replacement: step 15, image 2 of 2
      • With the pick tool still inserted, pull the red control module wire out of the push-in connector.
      Ask FixBot
    5. Dewalt Nailers DCN680D1 2018 Control Module Replacement: step 16, image 1 of 1
      • Repeat the previous two steps to disconnect the black control module wire from the push-in connector.
      Ask FixBot
    6. Dewalt Nailers DCN680D1 2018 Control Module Replacement: step 17, image 1 of 2 Dewalt Nailers DCN680D1 2018 Control Module Replacement: step 17, image 2 of 2
      • Unclip the solenoid's red and black wires from the control module's side.
      Ask FixBot
    7. Dewalt Nailers DCN680D1 2018 Control Module Replacement, Remove the control module: step 18, image 1 of 3 Dewalt Nailers DCN680D1 2018 Control Module Replacement, Remove the control module: step 18, image 2 of 3 Dewalt Nailers DCN680D1 2018 Control Module Replacement, Remove the control module: step 18, image 3 of 3
      • Lift and remove the control module from the device.
      • Reassembly tip: Make sure that the white plastic actuator latches into the black lever arm.
      Ask FixBot
    8. Dewalt Nailers DCN680D1 2018 Control Module Replacement, Transfer the loose components: step 19, image 1 of 3 Dewalt Nailers DCN680D1 2018 Control Module Replacement, Transfer the loose components: step 19, image 2 of 3 Dewalt Nailers DCN680D1 2018 Control Module Replacement, Transfer the loose components: step 19, image 3 of 3
      • Remove the white plastic actuator from the control module and transfer it onto your replacement part.
      • When you install the actuator, make sure the actuator bar can press the white button on the control module.
      Ask FixBot
    9. Dewalt Nailers DCN680D1 2018 Control Module Replacement: step 20, image 1 of 1
      • Only the control module remains.
      Ask FixBot
Arthur Shi
352,145 Reputation
937 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,931 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 89
All Time: 1,715
