Dewalt DCF885 Switch Assembly Replacement
    1. Dewalt DCF885 Switch Assembly Replacement, Battery: step 1, image 1 of 1
      • Press the battery release button at the top of the battery.
      Ask FixBot
    2. Dewalt DCF885 Switch Assembly Replacement: step 2, image 1 of 1
      • Pull the battery away from the tool.
      Ask FixBot
    1. Dewalt DCF885 Switch Assembly Replacement, Motor Assembly: step 3, image 1 of 1
      • Remove the eight 18 mm Torx Security #10 screws.
      Ask FixBot
    2. Dewalt DCF885 Switch Assembly Replacement: step 4, image 1 of 1
      • Separate the two halves of the outer case. Set the empty side down and out of the way.
      Ask FixBot
    3. Dewalt DCF885 Switch Assembly Replacement: step 5, image 1 of 1
      • Disconnect the connector from the motor assembly.
      Ask FixBot
    4. Dewalt DCF885 Switch Assembly Replacement: step 6, image 1 of 1
      • Pull the motor away from the brush assembly.
      Ask FixBot
    1. Dewalt DCF885 Switch Assembly Replacement, Brush Assembly: step 7, image 1 of 1
      • Lift the brush assembly out of the drill case.
      Ask FixBot
    2. Dewalt DCF885 Switch Assembly Replacement: step 8, image 1 of 1
      • Pull the armature assembly apart from the brush ring assembly.
      Ask FixBot
    3. Dewalt DCF885 Switch Assembly Replacement: step 9, image 1 of 1
      • Pry the two circled connectors apart from the brush ring assembly.
      Ask FixBot
    4. Dewalt DCF885 Switch Assembly Replacement: step 10, image 1 of 1
      • The brush assembly is now removed from the drill body.
      Ask FixBot
    1. Dewalt DCF885 Switch Assembly Replacement, Switch Assembly: step 11, image 1 of 1
      • Pull the switch assembly up and out of the drill case.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 52
All Time: 3,001
